Question about Gestetner DSm651sp All-In-One Laser Printer
Help! There is a red light by the printer light and at the top a key that looks like a wrench (?) is also red? It won't let me copy or scan.
    Scholar:
  • 126 Answers
You will need to reset your machine to clear the error.
Enter the SP mode by entering, Clear Modes, 1,0,7, then hold down the Clear/Stop Key for more than 3 seconds. Then enter the Copier SP mode.
To reset the DSM 651, enter the SC code reset(if you don't know the reset code check your manual, documentation or the side panels of your printer) and select '1'.
Next, depress the 'Photo mode' key. While depressing the 'Photo
mode' key, depress the # key at the same time and hold both keys for at least 3 seconds (it is not necessary to turn the main switch off and on). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to try the reset procedure again.
Posted on Jul 31, 2010
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
What's the meaning of a symbol looking red with a car/wrench on the instrument panel of a 2003 saturn l200? horn don't sound,ac won't work,doors won't unlock after ignition is turned off.
A wrench symbol is the equivalent to a check engine light. Take your car into a mechanic and let them diagnose the error code the engine light is storing to help diagnose the problem.
May 20, 2011 | Saturn L-Series Cars & Trucks
My Lexmark 8350 won't copy or scan. It appears that there is a problem with the light under the glass - it doesn't move when the printer tries to copy or scan. I tried to take the printer apart...
If you have already tried unplugging/replugging the printer into the power outlet in the wall to reset it, then I would strongly suggest you to contact Lexmark technical support for additional assistance. It's not advisable to take the printer apart as it would cause further damage if not attended by a professional. I apologize if I didn't have the exact answer that you wanted.
May 09, 2011 | Lexmark X8350 All-In-One InkJet Printer
Waste ink absorber is full
http://www.youtube.com/watch?v=VVpjqBr7KjU
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
thats how it is done on that printer, you need to look in the manual to check for yours.
Mar 26, 2010 | Canon PIXMA MP130 All-In-One InkJet...
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Gestetner DSm651sp All-In-One Laser Printer Logo
135 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
