Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
I have a fisher & paykel dishwasher. It has 2 drawers and the top drawer is stuck. It will open if I force it, so i'm using the bottom drawer. It just recently happened. Is it hard to fix?
  • Fisher and P... Master
  • 3,247 Answers
The lid seal of the top drawer is broken or has come off. To get to it you will have to take the two drawers out carefully along with the cables and hoses intact.
Then feel the top underside of the cabinet for the lid seal. Depending on the problem it will have to be replaced. There is an intricate mechanism of actuator arms and motors that drive it. I hope these are ok.
If you are lucky maybe the drawer has just come off the rails and you could put it back and it will be ok.
Please rate this solution if helpful otherwise drop a comment
Posted on Aug 16, 2010
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Jan 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
Is there a reset button on the dishwasher for the Fisher Paykel DD 605. I washed a top and bottom load, nothing unusual about the loads. The dishwasher just stoped and there is no power on either of the...
If there is no power on both the drawers then 2 things
1. the circuit breaker on the mains power supply feeding the dishwasher has tripped
2. the power board that feeds the drawers is faulty. This is located at the base under the bottom drawer.
The drawers won't open because the power has failed mid cycle and the drawer seal actuator motors are locked in down position.
You can force open the drawers but this could require some mechanical adjustments to the actuator yokes if the two sides are out of alignment when power is restored. In any case you will have to force open the bottom drawer to get access to the power board. The part looks like this but may not be the one specific to your model. You will have to contact a parts dealer local to your area.
The only reset function available is to turn the mains power off and back on.
Hope this helps. Please rate the solution if useful otherwise post a comment.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
184 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
