Question about Mitsubishi CS-31205 TV
Is there a vertical adjustment on model cs-31205? All of a sudden the picture is flashing and running vertically. Thanks
tvtek
  • 1284 Answers
SOURCE: Black box in the middle of the screen
To be exact it is in the TEXT mode within the Closed Caption menus.
Posted on Feb 18, 2007
techman
  • 3130 Answers
SOURCE: TV vertical height-Mitsubishi Model CS 35505
If the height has dropped down, you need to first find out why. Most likely there is a bad capacitor in the sweep power supply or the vertical output section. Good Luck
Posted on Oct 17, 2007
welcomejee
  • 10594 Answers
SOURCE: vertical deflection went out and now HV is going into shutdown
Get service manual / schematics from HERE and find why vertical uotput IC is blown in your TV.
Service Manual will also give you info how to perform vertical adjustments.
Hope this info will help you to resolve problem.
Posted on Aug 22, 2008
  • 9 Answers
SOURCE: i was just given a
your tv tuner is bad just take it out and resolder the tuner
Posted on Jan 11, 2009
maatmartin7
  • 1229 Answers
SOURCE: need vertical ic replaced and capasitors. do
Don, who says you need the vertical ic replaced? Although you are to the point as to where the problem is. I think the ic is ok. The ic is a 7 or maybe a 9 pin component. In some cases it could be 13 pins. If you are sure where the location is, it is mounted to a large heat sink. I am not real sure of mitsubishi location scheme . If you can find it, most of the time pins 3 and 4 will be shorted. Measure to be sure. I think it is good. Look real close at the pins. They may have rings around them..resolder these making sure not to use to much solder. They should make contacts between pins. Now examine the four or maybe 5 capacitors with corresponding numbers. replace them with exact values. Use High Temp 105 degree ones. If you decide to replace the vertical ic, removed the clip around it. It will be the LA78--- series, cross it with an NTE replacement. see your electronic store for parts.
Posted on Jul 08, 2009
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
Model 32 sf36a picture size
most likley they are in the tech menue
you would need the service manul to access the proper proceedure the cause may be caps going bad in the vertical circuit
Aug 29, 2009 | Televison & Video
I have a (very old) Mitsubishi CS-2655R TV. It's
You will need a soldering gun that has a smaller point and rosin core solder (smaller solder is better for this job) cost about $20-$30
Best way to fund the vertical IC without a diagram is follow the Green and Yellow wires from the yoke( coild around picture tube neck)
the Green and Yellow wires are the vertical winding and will get you close to the vertical output IC which should be standing straight up with about 8-10 pins going through the circuit board, using a magnifying glass verify if the pins have circle cracks around them and just solder them each heating them for a few seconds flowing solder to the pin not the soldering gun. verify that non are shorted (soldered) together that aren't suppossed to be. Sometimes the end ones or a few are together (usually a ground spot).
hope this helps
thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 22, 2009 | Televison & Video
Mitsubishi CS-31MX1. When first turned
no. capacitors in vertical circuit going south. sorry.
Dec 17, 2008 | Televison & Video
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Mitsubishi cs27403c tv problem
kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Jan 08, 2008 | Mitsubishi CS-27405 TV
Oct 16, 2007 | Mitsubishi CS-36609 36" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Televison & Video Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
