Question about Hampton Bay 24002 Ceiling Fan
Move existing ceiling fan to another location
How to remove existing fan & light assembly
    Sergeant:
  • 170 Answers
Make sure light switch is off.
start by unscrewing the fan blades. take out bulbs and bulb covers etc.
once all thats down the fan and light switch cover has three screws you can take out and unplug it to get it out of the way. look around the base for some more screws to take out and remove the big cover thats covering the motor. get it out of the way. now you will see the bracket thats holding the motor in place. remove them screws and bolts, but be careful and ready, the motor is heavy, and as it comes down, normally hamptom bay has a coat hanger type hook that will let you hook the hanging motor on the hook long enuff to disconnect the wires ONE AT AT TIME and then put the wire nut back on it just for safety. when they are all disconnected , you can un hang the motor , and then inspect the new fan bracket, it probably fits the same hanger. but if not, you need to take the bracket motor hangar down and get the wires out of it. if the light switch is off IT WONT SHOCK YOU. just dont touch the bare wires to your hands ANYWAY. if they touch each other thats ok. IF THE WALL SWITCH IS OFF. ok now its removed.
Posted on Jul 31, 2010
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
I purchased a reoplacemetn motor for my Nutone/Broan LS 100SE bath fan based on a reccommendation here. The new motor, part # 89169, came with five wires compared to the original motor's three. How do I...
The additional wires are for a starting capacitor, not included with the motor. The easiest way to hook-up is to order the Outlet Assembly p/n 88617000 (available at Coastal Tech Supply.) The assembly includes the capacitor, connector, and shroud; and will replace the existing outlet assembly in the housing. Minor electrical work is required to remove the old assembly and install the new one.
Mar 03, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I own a 2003 Dodge Durango. The coolant fan stopped working. I found a plug loose near the fan. Is it possible it came unplugged? If yes, then is the plug inside the fan case? I have looked all over and...
I couldn't find the plug or wire on the diagram on my online resource, either. The fan must have a cable going to it to operate, somehow, though, I agree.
Engine Cooling Fan Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Fan blade/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front - threads on viscous fan drive are right hand. CAUTION
      Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
      Do not unbolt fan blade assembly from viscous fan drive at this time.
    • Upper fan shroud attaching hardware
    • Upper fan shroud and fan blade/viscous fan drive from vehicle CAUTION
      Do not place viscous fan drive in horizontal position after removal because silicone fluid in the viscous fan drive could drain into its bearing assembly and contaminate lubricant.
    • Four bolts securing fan blade assembly to viscous fan drive.
To Install:
  1. Install or connect the following:
    • Fan blade assembly to viscous fan drive.
      1. Torque to: 17 ft. lbs. (23 Nm)
    • Fan blade/viscous fan drive assembly and upper shroud into vehicle
    • Fan shroud retaining screws
    • Fan blade/viscous fan drive assembly to water pump shaft
    • Negative battery cable
Sep 30, 2010 | 2003 Dodge Durango
Replacing fan clutch
prev.gif next.gif Engine Fan REMOVAL & INSTALLATION Except 5.2L Engines VISCOUS DRIVE FAN
  1. Remove the upper fan shroud bolts and lift the shroud from its lower securing tabs. Fig. 1: Remove the fan shroud 86743p24.jpg
  2. Remove the accessory drive belts.
  3. Remove the fan flange-to-pulley mounting nuts. Fig. 2: Remove the fan flange-to-pulley mounting nuts . . . 86743p25.jpg
    Fig. 3: . . . then remove the fan assembly 86743p26.jpg
  4. Remove the fan and viscous drive as an assembly.
  5. Remove the fan blade-to-viscous drive bolts and separate the assembly. To install:
  6. Position the fan on the viscous drive. Install the bolts and tighten them to 187 inch lbs. (24 Nm).
  7. Position the mounting flange of the viscous drive assembly onto the pulley. Install the nuts and tighten them to 18 ft. lbs. (24 Nm).
  8. Install the accessory drive belts.
  9. Insert the shroud into its retaining tabs and install the upper bolts.
Aug 11, 2010 | 1996 Jeep Grand Cherokee
I have ASrock P4vm800,Prescott800,Pentium 4 Pro.But i need a help.When it is powered up nothing happenes except the system unit ligth up,& chassis font panel ligth is blinking Continously.Cpu fan...
There is a verity of things you can check & or replace. You mentioned the CPU fan is not turning. This is very very important.
This suggests possible CPU fan is defective. Average life span for a CPU fan is 5 years or 50,000 hours. Your MB uses Intel PGA socket 478. For a replacement heatsink & fan assembly open the link provided;
http://www.amazon.com/Thermaltake-A4012-Cooler-Intel-Socket/dp/B000FEW8JW/ref=dp_cp_ob_e_title_0
A new heatsink assembly will come with a new fan attached to the heatsink.
It should also come with new thermal past or thermal tape attached to the bottom of the heatsink assembly.
As to the front panel LED light blinking continuously.
If the LED light is red in color this means your primary hard disk drive is trying to load windows.
My suggestion is for you to replace the CPU heatsink assembly first.
No need to remove the CPU from its socket at this time.
If you never replaced the Heatsink & fan assembly watch the video included below;
http://www.youtube.com/watch?v=4OB1hxxKdec
Once completed your system should function correctly.
If it doesn't, post you’re finding here & I'll help you further.
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
I am getting a P1481 code, From what I see it could be the Fan Clutch, but would it also cause it to shift at a higher RPMs, It only does it some time.
OK, loss of cooling fan speed. I will say this is plausible. I'll take your word for it (sometimes my online resource is not complete).
prev.gif next.gif Cooling Fan & Shroud Removal & Installation To Remove:
  1. Drain the coolant from the engine.
  2. Remove the air cleaner assembly from the engine compartment.
  3. Remove the air resonator assembly from the engine.
  4. Remove the inlet radiator hose from the radiator.
  5. Detach the transmission oil cooler lines from the fan shroud.
  6. Disconnect the fan clutch connector. Fan clutch removal and installation gm-03-00-1477.gif
  7. Use a J 46406 fan clutch remover and installer to remove the fan clutch from the water pump.
  8. Remove the upper mounting bolts from the fan shroud.
  9. Remove the fan shroud from the radiator by lifting the shroud and pushing inward.
To Install:
  1. Attach shroud to the radiator. Torque the bolts to 21 ft-lb (28 Nm).
  2. Use a J 46406 fan clutch remover and installer to install the fan clutch onto the water pump.
  3. Connect the fan clutch connector.
  4. Attach the transmission oil cooler lines to the fan shroud.
  5. Install the inlet radiator hose to the radiator.
  6. Install the air resonator assembly onto the engine.
  7. Install the air cleaner assembly into the engine compartment.
  8. Refill the engine with coolant.
Jul 22, 2010 | 2003 Chevrolet TrailBlazer
Need to replace 97 toyota camray radiator how do i go about it
Drain the coolant & recycle. Anti-freeze is toxic so please clean up any spills. Remove the top covers & trim to gain access to the fan & radiator. Disconnect the fan/sensor plug-ins and any other wiring to prepare the electric fan assembly for removal. You could have a line or two secured to a part of the fan assembly that will need to be removed. You've got a few screws holding in the fan assembly & then it pulls up & out. You'll need to remove the hoses & lines if auto trans, need to be raised or plugged to keep them from draining. fluid will drain out of the radiator once lines are removed so you'll need to catch that small amount of fluid in a pan or onto a shop towel. Now the radiator should be exposed with two mounts, one on the top left & one on the top right that have a few bolts to remove, lift up the mounts and the radiator will pull up & out. It fits into rubber grommets at the base, you'll need to line those up when reinstalling. I think that's it. Good Luck
Jan 27, 2010 | 1997 Toyota Camry
How to remove the fan blade in a 1998 suburban and replace it?
A Clutch FAN Requires the 4 Nuts/Bolts @ the Pully Bunched up in the Center Behind the FAN & In Front of Water Pump, Once Assmbly is Removed there are 4 BOLTS that Fasten the (FAN) to the CLUTCH assembly. It is Wise th REPLACE BOTH FAN & FAN CLUTCH ASSEMBLY AS A SET
Aug 28, 2009 | 1998 Chevrolet Suburban
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
194 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
