Question about eMachines ET1810-01 PC Desktop
Have a emachine et1810 and want to disable the onboard video
    Sergeant:
    Champion:
  • 277 Answers
Right click my computer
click properties
click hardware
click Device manager
click display adapter
yours will show
Right click your adapter
menu will ask...
After that is done. turn off computer instal video card and drivers and reboot
Posted on Jul 31, 2010
    Guru:
  • 1,082 Answers
Generally this is done in the BIOS. When you turn the system on, you will see a black screen with a line at the bottom to hit ESC, DEL or some other button to enter setup. You may have to start several times before you get it right.
Once in the BIOS you can turn the internal Video off. (Integrated NVIDIA® GeForce® 7050) This system is old and is not worth investing in a new video card. I'd consider a new system.
Disable onboard video on e machine w3653
Start device manager typing 'devmgmt.msc' in run box. Frome there you can select Graphics devices and disable the specific device.
May 31, 2012 | Computers & Internet
My emachien1810-01 does nit show any video. Replacing the video graphic card didnot solve the problem
Richard,
Only two things drive video. The graphics card and the motherboard. Sounds like m'board is eligible for a serious tech session.
May 17, 2012 | eMachines ET1810-01 (EMACHINES ET1810-01...
Prior to installing the radeon 4550 video card i followed the instructions and disabled the onboard video adapter via the device manager. I have the emachine model T6520. After disabling the onboard...
Hello
Try reseating the video card in the pci slot,remove completly then reinstall.
Also check your monitor video cable for being tight.
Last..Does this card require 24 volts? check for a 4 pin adaptor plug on the card.It may need its own power.
Apr 22, 2011 | E-Machines T6520 PC Desktop
Emachines ET1810 desktop computer randomly powers down for seemingly no reason. Doesn't crash or freeze, just turns off, as if the plug was pulled. Started about 5-6 months after buying.
It could be overheating, and automatically shutting itself down, to avoid any damage.
Did you get the standard 12 month warranty when you purchased the computer? Did you purchase "extended" warranty? If so, contact Emachines, and get them to trouble-shoot and fix it.
Jun 11, 2010 | eMachines ET1810-01 PC Desktop
How do I turn off the on board video in a e-machine w2686
Any PC that uses a motherboard with onboard video will either have a BIOS setting to disable the onboard video or it will automatically be disabled when you insert an external video card (AGP or ePCI).
May 14, 2010 | E-Machines eMachines W2686 PC Desktop
Emachine T6216 onboard video is shot (nothing on known good monitor) Have installed new PCI-Ex16 graphics care. Need to disable onboard video. Is there a jumper on motherboard?
Have you tried entering BIOS? I beliveve that you have to press and hold F1 during boot to enter BIOS. Once in there you should be able to disable onboard video card.
Apr 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
E210882 is the number on the motherboard on my Emachine computer. i'm trying to disable the onboard video card with a jumpper setting so it will reconize a older but working pci 3dfx monster 3d card I put...
You can disable the onboard by visiting your bios.
On boot it will tell you to press del f8 f2 etc to enter the setup from there you can navigate around to disable the onboard and choose the lane your older pci card is in.
Oct 11, 2009 | Dell (E210882) Motherboard
Video Card Upgrade Problems
Does this computer have an onboard video card?
If so you will need to disable this feature in the system BIOS.
It should be under onboard devices.
You will need to use the onboard card to enter the system bios and then turn off the onboard card. install the new card and then connect the monitor to it then power on the machine
Nov 30, 2008 | E-Machines eMachines Desktop PC
eMachines ET1810-01  PC Desktop Logo
339 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
