Question about Home
Need to gt the top off of a porcher toilet we can't fogure out how to get into the tank to fix whatever continues to run
    Scholar:
  • 67 Answers
I'm not sure why this is a challenge. The lid should just lift right off unless you have a wall mount toilet. Here is a .pdf of a typical Porcher toilet and how it all goes together. There is also a handy trouble shooting guide. If the toilet is running the culprit is either a faulty flapper or fill vavle. Let me knwo if I can be of any further help.
http://www.porcher-us.com/assets/documents/porcher/install/Install_3337.pdf
Posted on Aug 03, 2010
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
What is the flapper on a Porcher cistern?
It is the part that allows water in the tank. It closes or seals to allow the tank to fill up.
Feb 08, 2013 | Porcher Home
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Our Porcher veneto 1 piece toilet does not flush. Does porcher have recommended repair service near zip code 94901 ?
I have three of these beautiful babies from when I redid my bathrooms back in the early 2000s -- and one of them started to leak (would keep flowing a small amount into the bowl after filling the tank), so I did some online sleuthing and came across the parts as well as the how-to for a complete rebuild of the critical parts -- and rebuilt all three and they work like new. I am in zip code 94552 so if you need help from a licensed general contractor -- give me a call at 510-909-8813 and I can see if I can fix it for you (for a charge, of course).
Sep 12, 2012 | Porcher Toilet Onepiece Veneto ...
Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Jul 21, 2010 | Porcher Home
I have a Porcher one-piece toilet with a bad gasket. How do I take it apart and replace the gasket?
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Jan 05, 2010 | Porcher 40050 Classic Elongated Toilet...
The tank overflows
you'll need to adjust your float, so that it sits lower in the tank
Sep 04, 2009 | Porcher 97720-00.001 White Epic One-Piece...
Porcher veneto tank fills then every few minutes the water comes on to fill tank more,how do i fix it?
water level might be too high you can adjust the float so it dosent overflow or if the toilet flapper isnt sitting right could be leaking replace flapper and it should be good
Aug 20, 2009 | Home
Home Logo
681 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
