My 42' magnavox the screen went black still have sound but no picture I only have 2 years with the TV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 02, 2010
  • 8,457 Answers
Now,u turn on the tv?U get flashes of pictures only few sec. than died,have only sound left?Yes,than the 2 long board call the LCD inverter boards are dead.These 2 long LCD inverter boards must be replaced.These 2 long LCD inverter boards help the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these 2 refurbishes LCD inverter boards for the replacement.
Posted on Jul 31, 2010
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
Oct 11, 2013 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a 42 in magnavox 43mf439b/f7 tv. It is about 2 years old. i have no picture but i have sound. if i change channels the sound changes. I did a little research and i believe that i have...
You were smart to test the image for burned out backlights! :)
Typically, on a screen this size, the backlight inverter is the first place to look.
I found the part number...
27-D026774 Funai TV Module, backlight inverter, PNF10092, I420H1-16A0, 42MF439BF7
You can by it here...
http://www.tristatemodule.com/p-13231-27-d026774-funai-tv-module-backlight-inverter-pnf10092-i420h1-16a0-42mf439bf7.aspx
Aug 23, 2011 | Magnavox 42MF439BF7 42 in. TV
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Tv screen black
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you might need the expertise of a repairman.
Jul 01, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
