Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I am having a problem with my Cabrio top load. It starts the cycle on wash but when it gets to the drain and spin part and code LD comes up? Any idea what may be wrong? If I hit the pause button, lift the whole top of the washer up, and then hit the start button, the cycle will continue normally. Once it is drained down and goes into the rinse cycle, I put the cover back down, the machine will do the same thing again when it gets to the drain and spin cycle. I once again have to hold the cover up for the last 10 minutes of the cycle to get it to drain and spin out properly.
    Problem Solver:
  • 11 Answers
It is more than likely the lid switch
Posted on Jul 31, 2010
  • chrisdmachel Aug 17, 2010
    This was a good suggestion, but not the problem. I purchased a new lid switch and changed it out, but the washer is still doing the exact same thing. It is acting as though there is a intermittent neutral wire which will only make when I lift up the TOP assembly on the hinges.
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My whirlpool front loader cabrio stopped working with 12 minutes left in the cycle. The Ld code is flashing and I don't know how to fix it so that the load will spin and drain. How do I fix this...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I am having a problem with my Cabrio top load. It starts the cycle on wash but when it gets to the drain and spin part and code LD comes up? Any idea what may be wrong? I can unplug it for a while and...
W10049390 is the part you need to clean out or replace. Most likely it needs to be replaced. Lay the washer on its front face side remove back cover bought 6-8 1/4 in bolts remove hose's from pump and bolts and wire plug clean or replace and reassemble in reverse. DISCONNECT UNIT FROM POWER PRIOR TO MOVING IT!
Jul 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio top load washer won't start now but it first started by giving LD code when would wash only heavy items like full load of towels or bedding (all others ok). If I let it sit for awhile...
we ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
One day, it just stopped giving us locking problems.
Sep 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Giving ld code and won't spin
Hello Friend, (ld) means long drain. If it takes too long to drain it won't go into spin or other cycles. It's possible that you have a blockage in your drain hose or pump. Remove pump and check. I hope this info was helpful. Tim
Jul 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRLPOOL CABRIO WASHER
LD means long drain and will require a drain pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
531 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
