Question about Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quiet partner iii. The middle and upper spinner does not get any water. How do I fix this
Sorry, but I am having the same problem.
Posted on Aug 20, 2010
  • bobshappell Aug 20, 2010
    Doesn't anyone have a solution to this?
How do i remove the upper spray arm on a whirlpool quiet partner III dishwasher. It does not appear to be turning
There is a screw at bottom of arm. Try turning arm before taking screw out. I believe water pressure turns the arm, so if the arm doe not tur while machine is working then you either have a blockage from pump to arm or pump not working properly.
Aug 15, 2010 | Whirlpool Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Our Whirlpool makes a howling noise
Hello-  Debris in sump can cause noise, but if unit is 5yrs or older, motor bearings are failing. Part about 100$. Have installation instructions if needed. Let me know if this info helps -have more if needed. -Thanks-ED
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
178 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
