Question about Adobe Acrobat 9 Standard Full Version for PC
Adobe PDF creation cannot continue because Acrobat is not activated
  • Stan Gets Jul 31, 2010
    There is a very easy fix for this. Just delete the acrotray.exe from the C:\Program Files\Adobe\Acrobat 9.0\Acrobat, and then make a copy of AcrobatInfo.exe to the same directory. Then rename "copy of AcrobatInfo.exe" to "acrotray.exe" and there you go.
    Now you will be able to print to Adobe PDF
    basically this is a great way to disable "acrotray.exe", and by doing this it will open "AcrobatInfo.exe" instead, which does not do anything
lgc999
  • 39 Answers
SOURCE: Adobe Acrobat Reader
This is the same software. What type of printing problems are you experiencing?
Posted on Nov 06, 2007
proton77
  • 1183 Answers
SOURCE: missing pdf maker files
Solution Remove Adobe PDF from the Disabled Items list in the Microsoft Office application. To manage your Disabled Items list in a Microsoft Office application:
  1. Open the Microsoft Office application (Word, Excel, Publisher).
  2. Choose Help > About [the application name].
  3. Click Disabled Items.
  4. Select Adobe PDF from the list, and then click Enable.
  5. Quit the Microsoft Office application, and then restart it.
View an Adobe Captivate demo of this procedure
If the error message continues to appear after you enable Adobe PDF, then check the security level for macros in Word:
  1. Choose Tools > Macro > Security.
  2. In the Security dialog, click the Security tab.
  3. Choose Medium or High.
  4. Do one of the following:
    • If you chose Medium, then click OK.
    • If you chose High, then continue with steps 5 through 7.
  5. Click the Trusted Publishers tab.
  6. Check Trust all installed add-ins and templates.
  7. Click OK.
PDFMaker and the right-click context menu should function again.
http://kb.adobe.com/selfservice/viewContent.do?externalId=329044
Thanks
proton
Posted on Apr 02, 2009
Mrinny
  • 94 Answers
SOURCE: i want to print pdf files but the mesage
go to start...
control panel...
printers and hardware (or something like that where your printer is listed.)
Double click on your printer and the document queue window opens
Now go to file, right click and check if the 'use printer offline' mode is checked. Uncheck that and you should be good to go.
Otherwise there could be a problem in the USB port of that computer. Try and connect the printer directly to USB and not through an extension.
Posted on Jul 24, 2010
  • 2340 Answers
SOURCE: cant open pdf files. adobe not working
If you are using Win7, and you install Acrobat 8.0 on the system. Due to software compatibility the software is not going to work.
SOURCE: adobe acrobat 8 professional serialcode
If you would like to get a genuine serial number, I would suggest contacting Adobe directly about purchasing legit software.
Posted on May 16, 2012
Phone authorization code adobe acrobat professional 8.1.0
Authorization Code for Adobe Acrobat 8 ' Adobe Community - Adobe ...
https://forums.adobe.com/thread/1423529
Mar 8, 2014 - 2 posts - ‎1 author
I am trying to gtet my Adobe Acrobat 8 activated. ... When I called the automated system would not give me an authorization code, and when I hit ... an agent the message stating that phone activations are no longer accessible. Re-activating CS3 (Updated) ' Adobe Community ...
11 Aug 2017
Authorization code for acrobat pro 8 please ' Adobe ...
15 Oct 2015
Acrobat 8 Professional asking for activation af... ' Adobe ...
8 Aug 2015
Adobe Professional 8.0 Professional Activation ...
8 Jan 2007
More results from forums.adobe.com
Nov 20, 2017 | Adobe Computers & Internet
When I open a PDF file the program asks for authorisation code . The pop up says that the configuration has changed and I must activate now. The activation is unsuccessful. The serial numbers and...
Unfortunately, you will have to wait for a response from Adobe to correct this issue.
Nobody else can legally generate an installation or registration code for you.
Jun 03, 2011 | Adobe Acrobat 7.0 Professional
I want to scan to pdf on the hp 7310 all in one but it only scans to a file (jpg). How can I scan to pdf?
you will need to open a pdf creation program like adobe acrobat pro and scan while in that program. Then you can save it as a pdf. The scanning software will just scan it as an image.
Apr 20, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Hi! This is Adeel Saleem. I downloadde Adobe Acrobat 70 Professional Pro from the internet. It was successfully installed. Now whenever I open any PDF file, It says that you cannot use it till you...
Hello there,
This is because the version you have installed requires a license key to activate and you need to purchase one. However, if you just wanted to view and open PDF files, you can just download Adobe Reader from the list below which does not require you any license key.
http://get.adobe.com/uk/reader/
Hope this helps. Thank you for using FixYa. Merry Christmas!
Dec 24, 2010 | Adobe Acrobat 7.0 Professional
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
I want to install acrobat distiller 4.x/5.x. but i am unable to download freeware. please help-
Correct me if I'm wrong, but to my knowledge Acrobat never became freware...
There are many free PDF creation packages out there, for example PDF Creator, which has a GPL license.
Jan 24, 2010 | Adobe Photoshop 7.0 for PC
Problems with activation of adobe acrobat 8 professional
Follow these steps to install "Adobe Acrobat 8 Professional" :
1. Double-click on the setup file.
2. Folow the instructions, and the installation will continue.
3. When asked to activate the product, choose "More Activation Options" and "Activate Over Phone".
4. You will now be given an "Activation Number / Authorisation Code".
5. Use this code and serial to activate your product!
* Internet or Phone connection is required for "Adobe Acrobat 8 Professional" product activation !
please rate this advice if it helps...tc! :)
Jan 15, 2010 | Adobe Acrobat® 8.0 Standard Full Version...
I can't to open my adobe acrobat 8.0 profesional for laptop sony vaio, because i didn't have serial number. I need it.
If you want to open a pdf files then you can you Adobe reader or Foxit reader which are both freeware.
Adobe acrobat 8.0 is not a freeware and you need to buy the license key in order to installed the software and activate it.Do consider buying if you want to use adobe acrobat.
or else you used "Free PDF Editor"
Here is the downalod link
http://www.freepdfeditor.net/FreePDFEditor.exe
Happy New year...
Dec 31, 2009 | Sony VAIO VGN-CR220E/W Notebook
Using adobe acrobat professional - copy a pdf picture and paste into a pdf.
You can't just do it. Acrobat is not a document creation program.
You can either convert the picture to a PDF file and then append or insert that file in an existing PDF or you can use other program, such as an word processor to create a page in which you include the image and then convert to PDF and append or insert that page in an existing PDF
Dec 10, 2008 | Adobe Acrobat 7.0 Professional
Scanning from Canon image runner 2200
You may have to upgrade your adobe
Jul 20, 2008 | Canon imageRUNNER 2200
Adobe Acrobat 9 Standard Full Version for PC  Logo
1,836 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
