Need a lamp for a samsung hcl652w. - Televison & Video
  • 8,617 Answers
That model has 3 CRTs instead of a lamp. Which CRT are you needing? I can locate one for you but they are fairly exspensive.
Posted on Apr 24, 2008
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
Ihi i have a samsung sp 43t6hp and it looks like im watching tv in 3d how could i fix the problem
Sounds like you need a convergence board. Problem is there might be some transistors that you need as well. I've had a similar issue. Most places will cost $300+ to replace what might be a $15 part. Also there are 2 transistors in there that need to be replaced at the same time (once one goes the other is likely to as well). I would suggest calling Sears to fix it. They charge much less for the visit ($99 min charge) and will replace both parts at the same time.
Sorry I know that's not a true answer on how to replace the convergence board or other parts but mucking around in a rear project tv is a good way to get shocked. Those TV's hold a lot of charge even after unplugging.
http://www.searshomeservices.com/televisions/repair
Mar 03, 2011 | Samsung HCL652W 65" Rear Projection...
HOW TO INSTALL THE OS INTO THE COMPUTER? \
How to install the OS onto the computer; Click this link and please follow the instructions carefully; http://www.ehow.com/how_4424376_install-operating-system-computer.html OR this http://www.computerhope.com/issues/ch000647.htm For any query, email me to; rhojojoe@gmail.com Good Luck!
Jun 30, 2010 | Samsung HCL652W 65" Rear Projection...
My samsung hdtv is really dark not matter how i try to adjust the tv.
Hello! In this case, it can be two things either your lamp si goping out, or the ballast is. They're not that expensive http://www.discount-merchant.com/SAMSUNG-9137-008-22705-Lamp-Ballast-Driver-p/1138029.htm/?Click=48427 Of course you need to get the right part number. http://www.discount-merchant.com/Samsung-HLN5065W-OEM-Replacement-LAMP-BULB-p/samsung-hln5065w-lamp-oem.htm/?Click=48427 also for the lamp you need to get the right one you need.
Dec 06, 2009 | Samsung Televison & Video
Double vision dropped to the left about a half inch and a lot of red tone.
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Samsung HCL652W 65" Rear Projection...
Samsung dlp tv won't show picture when powered on.
Hi, you need to replace the color wheel, very common problem with your set, video-tek
Mar 26, 2009 | Samsung HCL652W 65" Rear Projection...
HCL652W
Your convergence ICs are defective and quite possibly the burning smell was likely some of the convergence Resistors burning. Its actually not that exspensive of a repair. you can get a brand new Sub deflection board for your set for 232.00 at the following link and that will fix your set and you just put the new board in. The site will also provide you with free on line tech support to assist you with installing the new board. you need the P54 Sub deflection board. Its available at the following link.
http://servicemanuals.vstore.ca/
Jun 13, 2008 | Samsung HCL652W 65" Rear Projection...
Hdtv 1080i
youre having a problem with the power supply. you will probably need a service manual to figure it out. Let me know if you want a link to purchase the service manual and get free tech support.
Apr 22, 2008 | Samsung HCL652W 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
