Our system suddenly stopped...there was a thunder storm but now evidence of a strike. I thought it might simply be the thermostat since it was blank. I replaced it and now have a beautiful programmable thermostat but no A/C action. Was told to check relay as well as reset...The unit is at least 12 yrs old but really would like to hold off on total replacement for a while. Can you help with location and ID of relay and reset button if that's even accurate. I'm going to go out and start taking the thing apart now and will check back when I have some specific identifiers. Carrier Tech200 (as best I can make out from what's visible on the outside). Nothing works...no fan no noise. and no smell as if something burned or seized. Thanks, Betsy
  • 1,476 Answers
I have to assume that you have the thermostat hooked up correctly and it will call for cooling when turned down.
From your description of the problem it sounds like the power circuit should be checked first. Locate the breaker in the electrical panel box and make sure it is not tripped. Next find the disconnect (it should be near the unit). It will be a small black (usually plastic) box. Open the cover and pull out the disconnect. It is possible you may have a disconnect with a handle you have to move to off to open the box.
Go back to the electrical panel and move the circuit breaker to the off position. Lock and tag the breaker for safety. Using a DMM on resistance check the fuses for continuity. If you have continuity. replace the fuses, remove your lock and energize the circuit.
Move to the evaporative unit, the unit outside, and remove the cover over the control circuitry (it should be obvious). There should be a relay inside which turns on the compressor and another to turn on the fan motor.
With the thermostat turned up enough to be demanding cooling use a DMM on AC volts and check the relay for 120 vac. If none is present look for more fuses on the circuit board and test them for continuity.
At this point if the relay has power, but the unit is not running, the relay is your problem and should be replaced. Remember to turn off the power and lock it out before doing any additional work in the control section.
If the relay is energized and engaged, and has power to the compressor, then you probably have a bad compressor and will need to access the unit and check the current draw on the motor.
After removing the cover to the compressor check for voltage at the compressor motor. If you have voltage do a current check. A tag on the unit will give you the locked rotor current draw. If you read that amount then you need a new compressor. This is a complicated repair and requires a license and special equipment. You will have to have someone else do this.
There is also an outside chance that the start capacitor for the compressor which should be located on the control board is bad due to the lightning strike. If your unit is 12 years old I would just replace it. They are not very expensive. It will be a large silver can with three wires on it in the area of the control board. If you want to test it read the voltage across it. If it is bad the voltage will be low, if good the voltage should read 120 vac.
Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 31, 2010
  • pjsplace2000 Aug 01, 2010
    Thanks but...what the heck? It's fixed....the little float sensor thing in the pan...come on....
My G Speak centurion intercom stopped working after a thunder storm.its just quiet
sorry but we have no information on your system here. might be a blown fuse .
Apr 24, 2018 | Televison & Video
Due to thunder strike, my tv power supply board got damaged. How can I get the board for UN40D6500 model
Simply Google it.
"Buy new power supply for UN40D6500"
I got several sites, but you will ultimately have to answer
some questions and decide on the one that best suits
you.
Jan 07, 2015 | Televison & Video
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Can a thunderstorm cause a tornado then?
Well yes it all depends on the thunder storm type like heavy thunder storms have a higher chance or creating a tornado compaired to light thunder storms and also it needs the right amount of humidity to run and the hot and cold air mix toghter too.
Mar 23, 2011 | Nintendo GameCube Console
Router quit working after storm
if that router stop working by thunder storm then buy a new one.. nobody can fix it.. or maybe to go electronic shop to refer to them...
Jul 15, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Has suddenly stopped connecting to internet on laptop. doesn't seem to get a signal or anything. main computer ok. seemed to stop after we had a thunder storm on thursday could this be something to do with...
Unplug your router. Unplug your modem. Wait 30 seconds. Plug your router back in and wait 30 seconds. Plug your modem back in and wait 30 seconds. Go to network connections under control panel. Right click on your network node. Enter enable. Wait a few moments and your network should come up.
Jul 11, 2009 | Belkin (F5D7633UK4A) Wireless Router
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
