Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
Stand by light blinks 6 times. if left unpluged for 3 or 4 days tv will come on but will not come back on if turned off. will stay on if never turned off.
  • 10,515 Answers
You almost certainly have two IC's in the power supply that need to be replaced. Only one is causing a problem, but they should both be replaced. You may be able to make the set come on if you try the power button enough times, that's how the IC's behave.
If you have electronics experience and can solder and unsolder electronics components, you might be able to do this yourself, but it's a fairly daunting challenge for the uninitiated.
This set has them located on a double sided PC board (the D Board) and it is much more difficult to service than a single sided PC board. You need specialized desoldering equipment to remove the IC's, and frankly, many otherwise so-so TV shops can't handle this. It's the rare servicer who has the ability to do this with care and skill.
When I encounter this board, I have to take the board away from the customer's home and work on it at my shop where I can do this procedure. Ballpark cost would be $350, and that's a little higher than it might be if it was a single sided PC board, because this board is so much more difficult to work on.
But the parts are IC6501 and IC8002, located on the D Board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2010
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
LG 32cs460-us TV black screen red light blinks 3 times
I can give you some advice on the first thing you need to try. Unplug the tv for 10 minutes. Plug the tv back into the wall or power strip. Try powering on the tv. This may work or may not. It is important to try this before moving on to more complicated troubleshooting.
Jan 20, 2014 | LG 32CS460
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
