Question about Refrigerators
I have a hotpoint fridge freezer FF187E the warning lights flash ( supercool and super freeze )also a warning alarm comes on is this due to temp failure.
  • 1 more comment
  • JIMI1 Apr 26, 2008
    I HAVE THE SAME PROBLEM PLEASE HELP IF YOU KNOW HOW TO
  • kabads Jun 01, 2008
    Same here - do you have the manual? Is there a description in there about what this problem is?
  • alanwilson3 May 08, 2009
    My fridgefreezer lights flash after I left the door open. I have tried turning down both temparatures to the off position and holding down the buttons it did not work now I see that the meat is almost frozen! please help
Solution #2 did the trick for me...fingers crossed!
Posted on Dec 30, 2009
I have tried the above solution without success. The only solution to the problem that works is to empty the fridge/freezer switch it off and allow it to do a full defrost. Then switch it on again. This appears to have sorted the problem
Posted on Jun 01, 2008
Turn the freezer dial (The one at the size of the Super Freeze Button) down to the 'OFF' position then back on again.
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Aug 04, 2009 | Refrigerators
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Flashing lights super chill super freeze
This is probably because you turned off the fridge at the mains (to defrost??). To stop the flashing lights and to restore normal operation, turn both the Supercool and Superfreeze knobs counterclockwise to "off" and then back to the operating position. Thats all!
Dec 21, 2008 | Refrigerators
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
731 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
