Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
BV1650 Weedeater. Start fine, runs constant. However, it runs way to slow. I have the Choke closed, and the Throttle on full. But it only runs about half the speed it used to. If I push the bulb once, it races to a faster speed but then slows back down within seconds. Ideas?
SOURCE: Poulan wt200 "wildthing" gas leaf blower
no compression wont start
Posted on Oct 16, 2008
  • 9 Answers
SOURCE: Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Posted on Oct 26, 2008
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
#1 Taper
  • 1041 Answers
SOURCE: Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Posted on Jun 05, 2009
rwvanlue
  • 486 Answers
SOURCE: At full throttle and choke off, blower slows down
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 16, 2009
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Weedeater Garden
How do I adjust the choke on cub cadet rzt-s
Generally there is a mechanical choke from the throttle linkage. The throttle may have slipped from the clamp at the carb. There will be a screw that holds it in place. Loosen this screw and move the throttle cable forward then retighten. You may have to remove the filter to see if the choke is closing at full throttle. This should help.
Feb 17, 2015 | Cub Cadet Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
95 suzuki 250 quad king, at full throttle it runs at half power, choke seems inop
First make sure your choke circuit is working. May be an indication that your carb needs to be cleaned. I wouldn't replace it yet= clean it. If the choke circuits and the carb check out fine. An unresponsive motor/ carb usually means bad valves or valve timing. Example: it runs rich, spits fuel out the carb no matter how lean you set it. Even with the idle air closed it runs rich... intake valve is not closing or closing late. In that case it needs valves serviced.
Aug 26, 2014 | Motorcycles
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 | Garden
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Will not run on open choke
HI,
I TALKED TO MY SISTER WHICH IS AN INSPECTOR FOR WEEDEATER COMPANY SHE TOLD ME IT HAS CLOGGED FUEL LINE OR THE TANK IS DIRTY. ALSO CHECK THE PRIMER BULB FOR HARDNESS OR CRACKING THIS ALSO CAN ALLOW A LEAN OUT CONDITION YOU ARE EXPERIENCING. EMPTY THE TANK AND WASH IT OUT WITH FRESH GASOLINE. SETTING FOR THE IDLE SCREW IS 1.5 TO 2 TURNS OUT WHEN TURNED OFF AND FULL THROTTLE SETTING IS HOLD THE THROTTLE WIDE OPEN AND TURN THE SCREW IN UNTIL MAXIMUM RPM IS ACHIEVED. HOPE THIS HELPS GOOD LUCK!
Mar 30, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
277 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
