Question about Uniden Cordless Phone
The phone rings once, then stops ringing
The phone in the other room continues to ring, however. I can answer the( uniden )phone with the problem but it only rings once then stops whereas the other phone--not a uniden--continues to ring until I answer one of the phones. I've pushed all the buttons in trying to figure out what happened so... anything help will be appreciated. Thanks
Remember to also disconnect direct tv receivers. I had the same problem untill I unplugged them from the phone line.
Posted on Oct 29, 2010
How do I increase the number of rings on my Uniden DECT 1715 series cordless phone. It rings twice and then stops.
press menu, go to answering set up find ring time press menu adjust the number of rings press menu then exit button
all explained in the user manual
Dec 02, 2017 | Uniden Lands Phones
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Change number of rings on uniden phone model exi 8560
The EXI8560 isn't an answering machine. It will continue to ring until someone or some answering machine picks up or the caller hangs up.
To change the ring count on your answering machine, consult the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Jan 14, 2014 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How do you change the amount of rings on the uniden dect1363 6.0 GHz
The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
Remote answer machine turn on
Most Uniden answering machines will turn on remotely after the 12th ring. Call your home phone and just let it ring, ring, ring.
Apr 09, 2009 | Uniden 5.8GHz Cordless Phone
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden Cordless Phone Logo
1,949 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
