Question about Thermador SC302T Electric Double Oven
When cleaning oven after 30 min. beeping and E 2 appeared
E 2 and lock appear in the screen after 30 minutes of cleaning. Beeping was going off too.
I turned the oven off, but the E2lock remains. Unfortunatly can't find my manual.
Hope you can help.
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
I just would like to clarify what you posted. Are you certain it is "E2" and perhaps not "F2" ?
The "F2" on the SC302 wall ovens indicates an overtemp was detected by the onboard watchdog in the control board.
( The lock indicator being on is simply a byproduct of the unit being in self-clean at the time the error occured ).
What this means can actually come down to a couple of things, either an intermittent temp sensor or ultimately a bad main relay board.
In the SC302 service manual I have instructs simply to replace the temp sensor. If the F2 reappears replace the main relay board...but not so fast.
* The one exception which is not mentioned in the manual but I have experienced first hand in the field is this...A tripped overtemp safrety cut-out.
Here`s what to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Jul 31, 2010
  • dano3250 Nov 08, 2010
    I need to do this to my oven - how do you remove the grill? I can't get to the screws because the door is locked :-) HELP!!!
    I'd love to get a copy of the complete manual also!!
    Thanks...
  • Mark MacDonald
    Mark MacDonald Nov 09, 2010
    Unfortunately the only way I know to open the oven door when in the lock position and it is inactive is a clothes hanger method. With the odd exception of resetting the house breaker which initiates the start-up watch-dog sequence...this rarely works, though it's worth a try.
    This of course is an exercise in patience as it will most often take many attempts to pull the lock to the right while pulling the door forward at the right moment so it opens.
    I can possibly provide the service manual, however it is too large to attach here so you'd need to provide an email address I can send it as an attachment.
    I'll watch for your reply. Please confirm your model number as they are not all the same and the service guides vary depending on the model number.
    Regards,
    Macmarkus :)
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
Trying to clean my oven. When I push the clean button it works for a couple minutes and then it starts beeping and an f5 code appears.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I am trying to start my self clean and a minute after I hit start a beeping with this code appears: FSEI
Make sure that the door latch is completly locked and then try again. If it is locked and you are getting this code the door latch assembly is bad. The oven sensor would be fine since you get no codes during normal baking. Problem is in door lock system
Feb 28, 2010 | Whirlpool RBS275PD Electric Single Oven
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Nov 27, 2008 | Ovens
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
415 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
