Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony KP-51Ws520 Tv wont power on. led light blinks 9 times and pauses.
  • 9 more comments
  • 070298 May 05, 2008
    i have the same problem where do u get the parts
  • Anonymous May 07, 2008
    I have the same problem, can I fix it my self?
    Is it fairly simple, or how much should it cost to get it fixed.
    Thanks.
  • edin1 May 19, 2008
    I have the same problem .. nine times blinks
  • Anonymous Jun 04, 2008
    same damn problem... this is silly
  • Anonymous Jul 16, 2008
    We have the same problem, blinks 9 times and won't power on. What is the solution
  • shorty634 Jul 17, 2008
    have the same problem tv onl 3 yrs old, how do i fix it
  • Anonymous Sep 05, 2008
    REDLIGHT KEEP BLINKING
    RED LIGHT BLINKS
  • curt williamson Oct 20, 2008
    red light blinks 9 times and no picture. Tried to order board but not ava. Can u order the diodes? Are they hard to replace? thanks
    red lights blinking and no picture. Can't find G board so can I replace the diodes? Is that pretty easy to do and where is the best place to buy them? Thanks
  • thomozzy Jan 25, 2009
    i have the same problem. Where do you get the g board?
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
If the Diodes are not open then you need to remove all the existing solder with solder wick and clean the diode leads and re-solder.I have fixed 2 other sets this way.Sony used solder that was not very good at the time. And they are on the G board part of the input power.
Posted on Jul 05, 2008
  • LaRoy Gibson
    LaRoy Gibson Oct 02, 2015
    PART # HAS CHANGED,REASON WHY PEOPLE CANT FIND IT THE PART # NOW IS 9-910-999-Y1
  • Sony Master
  • 8,617 Answers
Diodes D6116 or D6306 is open on the D board. thats usually what causes that error code.
Posted on Apr 24, 2008
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
I have a Sony Kp-51ws520 5 blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
10 BlINKING LIGHTS ON SONY TELEVISION
in these sets you have to check the power supply board. check all capacitors maybe blown on top.
Jun 07, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520
Have you checked your fuse? As the led should light up. Do you hear any relay clicks when you press the power button/ Please respond to this same post.
Jul 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
2,692 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
