Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Refrigerator side is saying its 34 degrees when its really like anywhere from 51 to 59 degrees inside of. Its just not staying cold on the Refrigerator side..do you have any answers for this problem
  • dcswv Jul 31, 2010
    I have a Samsung RS265LABP model....the refrigerator side is not staying cold the freezer door has digital settings and I have it set at 34 but its always between 51 and 59 degrees.....any answers for this problem
  • Samsung Master
  • 1,511 Answers
Hello and Welcome to FixYa!
The Refrigerator is not properly cooling. That could happen due to several reasons. You need to cross check the below quoted components one by one in details in order to trouble shoot the problem.
  • Make sure that the compressor and the compressor motor is running and working properly.If not check the compressor, Thermostat, overload relay and the capacitor.
  • Check and set the thermostat to the optimal settings.
  • Afterwards check the condenser (dirt or lint) and the Evaporator coils (Frost Built up due to self defrosting unit malfunction), because that can also cause the cooling malfunction or poor cooling.
  • Also do make sure that the doors are properly sealed and the gaskets are intact.
Above are all the possible conditions for the quoted query. Please cross check each possibility carefully and you would have the bottle neck of the trouble you are facing.
Best of Luck,
Please Do RATE the solution, if you feels this helps you,
Concerned.
Posted on Jul 31, 2010
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
You need to clean the coils . The condenser coils under the unit or evaporater coils inside the freezer. The coils inside could be iced over because of failure of defrost system.
The condenser fan under the fridge works? Does the fan in the freezer work, which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temp. control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.Thank You for contacting Fixya and please accept the solution if it has helped you.
    my refrigerator is a Samsung model RS265LABP it has digital settings on the outside of the freezer door si I have the settings on set to what I want.The fan is working fine because I can hear it hitting something when it comes on.Probably ice build up Im trying to find out whats causing the build up and or what I can do to get it to stop...its like the auto defrost is not working
Have a Kenmore side by side refrigerator freezer gets cold but refrigerator side stays at 40 degrees
The refrigerator of fresh food side is supposed to be around 40 so its working correctly.
Feb 27, 2015 | Kenmore Refrigerators
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Refrigerator temp too cold. won't stay at 34 degrees.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 04, 2011 | Samsung RB215LASH
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Temperature reading incorrect
there are thermistor,sensors and themal fuse by the evaporater on fridge side have to take plastic cover off evap but is prob over frozen and will need defrosting these are quite complicated.
Sep 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Refig set at 34 degrees and it might be about 45 degres inside what could be the problem
How about the freezer? Is it cold (about 0 degrees Farenheit). If so, there's probably ice build-up blocking air flow from the freezer to the fresh food compartment. Even though modern refrigerators are 'frost free,' they're really not. Over a period of time, frost can build up in areas where air flow is restricted (like the door that controls air flow between the freezer and fresh food compartment). Take everything out of the refrigerator and freezer and allow both to defrost completely. To avoid an odor problem, clean out any food residue that may have been masked when it was frozen. Be sure to LEAVE THE DOORS OPEN while you're cleaning and until you're ready to turn the unit back on and put your food back in. Hope this helps.
Jun 11, 2009 | Samsung RS2534 Side by Side Refrigerator
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Refrigerators Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
