Question about Fujitsu Siemens Siemens Silver Line S5 15" LCD Monitor
No electricity on screen. How do I connect LCD doesn't work
    Brigadier General:
  • 10,406 Answers
Which is cheaper:
* spending $50 to $75 to have a qualified technician "trouble-shoot"
* spending $50 to $100 to buy a used 17" (not 15") LCD monitor?
Posted on Aug 01, 2010
How to replace a cracked screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 06, 2012 | Computers & Internet
Lcd replace
You should the installation instructions with the new lcd screen
Hope this helps
watch video
Nov 04, 2012 | Computers & Internet
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
Screen is non-functional and irreparable
hope this helps
Sep 17, 2012 | Computers & Internet
My dell latitude d800 dosnt start. no cursor no splash screen ..only lightning some buttons..
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Sep 03, 2011 | Dell Latitude D800 Notebook
Lights come on, but blank screen
Hi estees823,
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
Hope this helps.
Jun 20, 2011 | HP Pavilion dv9000z Notebook
When you hit the on button you only see on screen is black. what's wrong with my laptop?
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite A205-S5809 Notebook
My gateway laptop didn't start up,when powered on only black screen appears
Hi jeangray 17,
Hope this helps.
Jun 05, 2011 | Computers & Internet
My Aspire 6920g has the screen completely blank and I can hear it work. What is going on? Any ideas?
Hi ribeiroal,
Hope this helps.
Jun 03, 2011 | Acer Aspire 6920-6422 Notebook
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Fujitsu Siemens Siemens Silver Line S5 15" LCD Monitor Logo
224 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
