Question about KitchenAid Refrigerators
Ice maker seems to be frozen in mid cycle, thereby stopping ice production
  • 3,230 Answers
Well first of all you can check to see whether the ice maker has been turned off. After than you need to check the Supply Valve,  Thermostat, Water Inlet Valve. For further help or information you can please post the Model Number of your Refrigerator.
Good Luck!!
Thanks
Posted on Jul 31, 2010
Ice machine not making the ice
Almost all ice makers have a on/off switch. I did not see in your answer that you did not checked it.
Assuming the switch is in on, in most ice makers there is an electrical plug that provides power to the ice maker. To check this plug you typically have to remove a couple of screws that anchor the ice maker to the cabinet. After removing these screws, lift out the ice maker until you can see the plug. If it is not plugged in, plug it in.
There is also a bin switch in many model that needs to be lowered in order for ice production to commence. It will look like shiney metallic bail and needs to be lowered. During normal ice production, as ice is harvested the fresh batch will push on the this bail and if it pushes far enough it will cause the controls to stop ice production. Once the ice level lowers and the bail is allowed to lower, ice maker will start making ice again.
Hope this helps
Dec 13, 2014 | Maytag Refrigerators
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Water dispenser is working but it is not making ice
Hi and welcome to FixYa, I am Kelly.
You did not include a model number so this is very generic. When an ice maker slows or stops production often the problem is not the ice maker but a symptom of other problems. The biggest reason they stop working and you still have water in door is that here is an ice block on the evaporator coils. The freezer has to cool down to 14 - 16 F before the ice maker thermostat will actuate and begine the harvest cycle.
There are other reasons they stop working
1. The inlet water valve solenoid has failed
2. The inlet water valve is clogged with debris only on the ice maker supply side.
3. The ice maker thermostat fails
4. The ice maker fill fill tube is frozen closed ( 5. The ice maker module or (optics depending upon model) has failed
6. The evaporator fan is turning to slow or not working.
If you would respond with a model number I may be able to send you links to a manual or 2 that would help you troubleshoot.
Now... back to the beginning.. IF you note ice build up / lots of frost in the back of the freezer do the following:
1. Unplug the unit and remove freezer contents
2. Direct a fan into the freezer compartment for just about 2 hours. (water mess)
3. While the unit is defrosting open the lower back of the unit (Compressor area) and clean the condenser coils and fan. Make sure to also clean the drip pan and the END of the compartment drain tube.
4. Clean up the water mess and return the unit to normal service.
If it starts making ice in 6 - 8 hours you have an automatic defrost system problem. Possible causes for NOT defrosting automatically:
1. Defrost control or timer failure (depending on model)
2. Defrost heating element failure
3. Defrost thermostat or thermistor failure depending upon model.
4. Wiring.
Everything should be fine for at least 2 days. If there is an automatic defrosting problem, the ice production will slow and then stop as more ice builds up on the evaporator coils.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
19 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
