Hi, I have acquired a Samsung sp43w6hl rear projector TV with a cracked screen (mad up of two layers). Any idea if and where I could obtain a replacement screen, as the tv works fine?
  • 298 Answers
SOURCE: CRACK LCD TV SCREEN
See this post
http://www.fixya.com/support/t429036-crack_lcd_tv_screen
Posted on Mar 07, 2008
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
  • 84 Answers
SOURCE: LCD TV with broken screen, good picture??
You can have them repaired using a TV Repair guy but often it costs as much as a brand new plasma. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
SOURCE: Samsung TV Model number HCR4751WX/XAC
hmm i just got a samsung hcr4751wx from my work they are putting it in the garbage because they said it doesnt work. when i plug it in a red light just flashes. anyone have any ideas whats up?
Posted on Aug 04, 2008
I got the screen for my Dell 6400 from www.screencountry.com and it was even cheaper that ebay deals.
Posted on Aug 20, 2008
Can the screen be replaced once it is cracked
Yes, and most times the screen is plastic and made of 2 or more layers. You may be able to just remove the cracked piece for now unless all the layers were cracked...
Oct 22, 2010 | RCA P52926 52" Rear Projection Television
Where do I get a new hitachi tv screen because mine has a crack in it?
Your best bet is to check with local repair shops and see if they may have a used one as these screens are rather expensive. These screens are actually lenses. Also they are two, sometimes three layers thick. The two layer screen is composed of a Lenticular (outside) and Fresnel (inside) lense. The third layer sometimes used is in front of both of these and is a protective screen. You can live without this one if necessary.
Aug 30, 2010 | Hitachi 50UX57B 50" Rear Projection...
Hi guys I would like to know how old the SP43W6HL is? I have had mine for two years and would like to sell
Look in the back for manufacture date.But as i remenber these set are mostly produced in the years of 2001-2005 the high light of these tvs models.My best estamate as used and good conditon tv.Max price u could get for it about $800 max.
Jun 10, 2010 | Samsung SP43J6HD 43" Television
THE SCREEN ON THE PANASONIC PT-53WX42F CRACKED WHILE MOVING IT
Depending on how bad, there are many layers of screen, if the outer layer is smooth and does not have ridges you can use a piece of Plexiglas to replace that. although glare may be more prevalent with a Plexiglas replacement. if the outer layer has ridges or more than one layer is broken there is not much you can do yourself. The screen from the manufacturer is cost prohibitive to replace. But if you have a local tv repair shop they may have a junk one, that they can sell you for a reasonable price. If it is just a small corner it might be better not to do anything at all, when you watch a tv it is the middle of the tv you watch and the corners are hardly noticeable under normal tv watching, although it may bother some people that the crack exists it actually may not cause you much discomfort watching the tv.
Oct 12, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Hi I have a cracked Samsung LE25r51bd screen, how
this is a projection television? ive been using prspex in my shop for damaged projector screens, its in expensive and alot easier to source than the brand name or an original one. good luck.
Aug 16, 2009 | Televison & Video
Cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Replacement Screen for 65 " Sony Color Rear Video Projector
Try HERE to get replacement screen for your TV.
Good Luck.
Sep 26, 2008 | JVC AV-48WP30 48" Rear Projection...
Cracked Plasma
For the cost of the replacement screen, it's a better option to replace the unit I'm affraid.
The only time you would consider repairing this would be if it were a part of say a video wall and needed to match the rest of the units.
Apr 16, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
BROKEN SCREEN
Order one from Vance Baldwin Electronics at www.vancebaldwin.com.
Dec 21, 2007 | Hitachi 51S500 51" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
