Question about Insignia LCDTV26 26 in. Television
TV keeps cutting off
I bought this tv 5 years ago and for the last 3 years, it's been cutting off when I turn of and I have to keep turning it on everytime t cuts off sometimes for over an hour before it even stays on. I have it in my bedroom, so it' hardly ever used or used only when I wake up on weekend nd lay in bed.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
A very common problem for this set has been bad electrolytic capacitors on the power supply. There are 2 in this model that are 1000uf at 35 volts that will commonly cause this. When they go bad they will normally be domed or mushroomed on top rather than be flat, so they should be easy to locate. If you can solder, they would be easy to change yourself. You can get the caps just about anywhere online for only a few dollars. A repair shop would probably charge around $100 to make this repair if it is indeed bad capacitors.
Posted on Jul 31, 2010
I have a mitsubishi 3d dlp tv model wd-73640. The lamp keeps burning out. We have replaced it 3 or 4 times in a year. Do you have any idea why this keeps happening?
These lamps should last around 5 years so I can understand your frustration.
Normally the lamp life is shortened by heat issues? Do you have enough space above, to the sides and back to let air flow in and out of the television? Are all fans working? Are the fans staying on for a while after you turn off the TV?
If you're using a power strip to turn off the TV the fans can't run when the television is turned off and it won't cool properly.
Oct 05, 2015 | Mitsubishi Televison & Video
Headphones keep going quiet.
I would return them and either get a new one from them or another manufacturer.
May 11, 2017 | Sennheiser RS 110 Consumer Headphones
I have a samsung HLR6156WX. Bought it new 5 yrs ago gets very very little use (guest area). Turned it off and now it wont come back on. Ive read different post about slappint the left side after leaving it...
amount of use does not counter the fact the tv was 5 years old. a blub not used for 5 years can still burn out just like any other bulb. the only thing you can do is get it replaced.
May 02, 2011 | Samsung Televison & Video
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips
if you bought it under one year ago then the retailer should be obliged to either replace it or repair it. I would look into this further, ask to speak to the manager or something casue when a tv switches itself off it indicates an error inside and turns itself off to prevent further damage.
Jan 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Tv willnot turn on
Mine just did the same thing on the same day, same tv. we bought ours from Walmart exactly one year ago and after spending time on internet, i have found that alot of us with the same tv have had same problem with no avail from RCA company or walmart. i can't get help from anyone and am ready to scream. Good luck. Others have told me that they have had repair man out and said that it was a malfunction is some type board that he has seen over and over in this tv and he advised to just buy another tv because it was too costly and the problems were going to keep coming with this specific model
Apr 06, 2008 | RCA P52812BL 52" Rear Projection...
Insignia LCDTV26 26 in. Television Logo
99 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
