Question about Chamberlain 34HP Whisper Drive Plus Evercharge Standby
How do I change the batteries in the keypad remote
    Sergeant:
  • 170 Answers
Look for small screws and remove them. unless it has a sliding cover. if neither one applies, sometimes a small knife pops it open. some of them have snap together housings that jsut require a little prying
Posted on Jul 31, 2010
  • 10,865 Answers
Hello. Unscrew it from the wall and u will see the battery compartment on the back side near the bottom. J.
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a craftsman garage door opener Model: 139.53876, FCC ID: HBW1162 the battery died in the remote and we changed them, not sure if this changed the code but it won't open, my father in law changed...
Changing the battery should not reset the code. Check that the battery is inserted the right way round. If the battery 'died' the metal terminal contacts inside the remote/ keypad may also be dirty. You could try gently scratching the surface of the contacts with a small screwdriver to restore brightness if they are discoloured.
Feb 15, 2011 | Craftsman Drills
Craftsman 1/2 hp opener won't open using the outdoor keypad. It will close when using the outdoor keypad but not open. Wall unit closes and opens it. changed battery in keypad, no difference
If your hand remotes work okay then the keypad has lost signal strength and needs to be replaced. If your hand remotes act the same way then your logic board is bad.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote works randomly,changed batteries now the
Keypad flashing is normal. Sounds like you may have a bad logic board. Try programming everything.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Change battery in GICT390 3 button remote
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries.
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 34HP Whisper Drive Plus Evercharge Standby Logo
133 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
