Question about Homelite Garden
I have a homelite blower model UT08580. I have replaced the tank (cracked) and the carburetor,I have spark but will not start... suggestions?
  • 10,865 Answers
Make sure you have a new air filter, new spark plug and fresh fuel. Then get a can of starter fluid and a helper. Squirt some starter fluid at the air intake and start it. Have your helper continue to squirt the starter fluid to keep it going as this will clean out the entire combustion chamber. J.
Posted on Jul 31, 2010
Is my Homelite blower model UT08580c the same as UT08580
The "C" denotes some minor change in the product, so yes the carb should work. The change can be as simple as the color or the packaging
Oct 11, 2016 | Homelite Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
Redmax blower older model does not start, tried a few drops of gas in spark plug port and it started. but stalls after fuel in burned off, any help would be appreciated, djk913
Carb. problems sounds mostly like the carb needs to be thoroughly cleaned out, drop fuel bowl and hit openings with a tiny steel wire and carb cleaner also check the diaphram, sounds like its cracked/dried up.
Aug 02, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a Homelite leaf blower that will start and run for a half tank og gas. However when the tank is half empty it stalls out and will not start. If I stop it fill the tank let it sit it will start
Sounds to me as though the fuel line that supplies the carburetor has been pulled out so that it is above the fuel when tank is 1/2 empty, or there is a crack/break in the fuel line inside the tank. Not a hard job to replace the fuel line, but takes patience. If your machine has 2 lines, only take 1 off at a time to avoid confusion as to which one goes where on the carburetor.
Dec 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Starts but dies after several seconds
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | Homelite Garden
Homelite bx90 leaf blower: won't run in cold weather
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Oct 20, 2009 | Homelite Consumer Products Backpack...
Garden Logo
201 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
