Question about Citizen Eco-Drive BL006056H Wrist Watch
Need to shorten my band citizen Eco-Drive divers watch
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
Apr 27, 2014 | Citizen Eco-Drive BL006056H Wrist Watch
Taking off a link from a citizen eco drive watch band
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, You"d need a tool to remove that link, by the time you get the tool, the time to remove the link, is about the same cost of haveing a shop do the job.
Jul 04, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
Citizen Aqualand eco drive divers watch.
Give the watch a good charge under a lamp for 24 hours , not close to the lamp so it get real hot.
if it does not hold charge after this i would contact Citizen as the capacitor may be faulty.
Aug 25, 2017 | Citizen Eco-Drive Aqualand BJ2004-08E...
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Watchband is one segment too long
You need the a watch link remover tool. This can be purchased online or a jeweler can do it for you. I would take the watch to where you purchased it and they should do it for free.
Jan 02, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Item number L12445 band adjustment
How do I shorten the links on a woman's eco drive citizens watch band?
Apr 22, 2008 | Watches
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco-Drive BL006056H Wrist Watch Logo
2,701 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
