ry ( FQS07SVR)-your missing driver I use it for windows 7 and it works perfectly for my qs-7 printer I posted a step by step also in same thread some time ago its in SysWOW64 inside the windows file on drive c one other person tried it and couldn't get it to work but mine is fine -good luck heres the afore mentioned guide in case its any use
How to Make the Fuji-QS-7 PHOTO PRINTER Work in Windows 7
Finally reconstructed the steps I took to get QS-7 working perfectly in Windows 7 The following is for dummies like me so bear with it
Step 1 connect up printer as normal leave it switched off
Step 2 on the C drive of your computer access the Windows file
Step 3 from the available items listed select SysWOW64 and open it
Step 4 scroll down to the application name FQS07SVR Right click on it and select the option Run as Administrator (if you hover over it with the mouse it shows exactly what it is- the seemingly missing printer driver for the QS 7
Step 5 when you run /install this al you will see is the window that opens when using command line for about 1 second blink and you miss it
Step 6 switch on your printer and allow Windows 7 to do its thing it will tell you after about 20 seconds that the printer is ready and drivers are installed
Step 7 go to devices and printers it may show you 2 entries for the QS-7 one of which is labelled copy 1 and is strangely greyed out- use this one when selecting print from QS-7 in future -GOOD LUCK! and please let me know if you are successful as this is all I did and now my printer works even though Microsoft's engineers and Fuji say it isn't possible.
Disclaimer -This solution offered only to attempt to alleviate the suffering of those left out in the cold by less than helpful technical experts and unsympathetic companies I can in no way be held responsible for anything that might go wrong
But its worth a go .
Another opinion:
The Fujifilm Finepix Printer QS-7printer is not compatible with Windows 7 as per the Fujifilm's website:
http://www.fujifilm.com/products/photo_printer/finepix_printer/#faqs However, if you received the driver disc along with the printer, you can install the vista drivers in compatibility mode.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
