Screen shows different colour grids when starting then goes black with message in right corner "out of range"
    President:
  • 2,712 Answers
Hello ssi1,
This happens when your screen resolution is set to something higher than what your monitor can display. For example, if your monitor supports resolutions of up to 1024x768 and your video card allows you to crank it up to 1600x1200, doing so will give you an error. Another reason you might get the error is if the refresh rate you selected a certain resolution is higher than what your monitor supports. The monitor can't "sync" with the video card, so it just gives you that "Out of Range" error.
However, the first thing to do is check that the cable between the monitor and PC is plugged in all the way and is secure. If possible, try using another cable and see if this helps.
Next, either change the refresh rate, or change the video adapter settings, or both.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2.
Right-click the desktop, click Properties, and then click Settings.
3.
Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4.
Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties. )
To change the video adapter settings:
1.
2.
3.
Click Advanced, click Adapter, and then click Change.
4.
Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5.
Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6.
Click Standard Display Adapter (VGA), and then click Next.
7.
Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8.
After the computer starts, right-click the desktop, click Properties, and then click Settings.
9.
Click 256 colors, click Apply, and then restart the computer.
10.
After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11.
Click Device Manager, click View devices by type, and then click Display adapters.
12.
Click Standard Display Adapter (VGA), click Remove, and then click OK.
13.
Install all updated monitor drivers.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free holidays, meals, haircuts and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Posted on Apr 24, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
Where is the density sensor on hp cm1312 colour laserjet?
thank you for your advise. we are having this problem, light black printer, colours are not good. we thought of the laser scanner, but thats above...as opposed to looking down, where toner can fall during print.
Dec 29, 2011 | HP LaserJet CM1312 All-In-One Printer
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Since changing the ink cartridge for the first time it now won't print. Sometimes it will print absolutely nothing although it seems to go through the motions but page comes out blank, sometimes it will...
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Nov 15, 2010 | Office Equipment & Supplies
After Windows has started and the setup screens show, my Kogi monitor says "out of range" and the screen goes black. How can I fix this?
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
Sep 06, 2009 | Computers & Internet
Grid surrounding cursor and desktop icons
You have accidentally enabled "Universal Access"
Open System Preferences from either the dock or the pull down menu under the Apple in the upper left hand corner of your screen.
In System Preferences the 4th line down should have icons for "System" one of those icons (usually the right most) will be a blue circle with a person in it. This is "Universal Access"
Open Universal access and turn voice over and zoom off.
Feb 28, 2009 | Apple iMac G5 Desktop
No Full screen and failing display driver
i recommend you to download and install a fresh driver from ati website there might be some files missing in the vga driver
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
