Question about Homelite ZR10926 16 Chain Saw
My chain seem to be sticking in spots - Homelite ZR10926 16 Chain Saw
    President:
  • 2,220 Answers
Did the chain come off while at speed? I think you accomplish the top part of this you will find your problem.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 31, 2010
Chain won't move after chain replacement
Had this happen to mine when I was limbing stuff that was too small. I know better. There is probably a burr on one or more of the guide portion of the links where they run in the bar. This causes that link to be tight in the bar at this point. The chain probably hit something on the body of the saw when it flew off. Take the bar off the saw and run the chain through the groove in the bar. If you have any links with nicks, they will bind, causing the chain to stick and not run freely. Once you've identified the problem links you can remove the nicks using 120 grit paper backed up with a flat piece of steel so you only remove the high spots.
May 05, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
94 cbr 600 f2, when rolling down on throttle and reducing speed, i hear chattering noise. once i pull in clutch or throttle up, noise goes away. seem to think its trans syncing or grinding teeth. am i...
No, the syncing only comes into play when you are SHIFTING. What you are likely hearing is a chain hitting something during deceleration. Look into chain thightness. Remember to check the chain at it's tightest spot. That means you need to carefully roll the bike, while feeling the chain, for 10 feet or so. Just find the tightest spot of the chain's normal rotation, and adjust at that spot. )Failure to do this burns out bearings quickly.)
I bet you are just slightly out of adjustment....it is normal. Also, clean your chain and lube it when hot.
May 11, 2011 | 1994 Honda CBR 600 F(2)R
Seems chain is loose. every 3 pedel in skips and recatches sprocket. could be trying to change gears but doesn't look like it is, think its just loose. huffy nightstalker 12 speed
Sometimes chains have stiff spots that cause them to skip. You can try checking the chain for stiff spots or just spray some lube on it and see if it loosens up. If you turn the bike upside down or put it such that you can let the back wheel spin freely, you can slowly turn the pedal and see if you can see the spot on the chain where it slips. If you find it, you can spray lube on the spot and work it back and forth until it's loose. Good luck and hope this works!
Mar 14, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Honda vibrations
This one's a little tricky cause it could be a few things.
I'll try suggestions in the order of probability
  • Worn out chain & sprockets.(Or chain too tight or has a tight spot) Check this by raising the rear wheel off the ground,in neutral & spin the back wheel. If the chain & or sprockets are worn you'll feel it & hear it when you spin the wheel. If it has a tight spot,set the chain tension at the tight spot & lubricate well
  • Loose engine mounting bolts. If loose re- tighten.
  • Worn front sprocket shaft bearing. to check this(if chain seems ok) Remove the chain(note joining link direction of the circlip. The closed end faces the direction of rotation)Bike in neutral, turn the sprocket shaft by hand. It should turn smoothly.If it is notchy thats not good. It is a major job to change & can be expensive(So i hope its the chain &/or sprockets)
  • Broken tooth on a gear in the gearbox. I hope not as again a more difficult & expensive repair.
Hope this helps you narrow down your problem
Regards Andrew Porrelli
Dec 03, 2009 | 2001 Honda Cityfly
White spots on 50 in. Viore
the pixels are sticking . slow degeneration of the display panel
Jun 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Slapping noise after chain adjust
hi there,,1,5, to two inches is correct,, is that all the way round by the way, sometimes u can have a tight spot,,it seems correct sometimes wen adjusted in one position,, but spin the rear wheel round it will either slacken quite a bit,, or go very tight,with no play in it,,,your cush drive rubbers behind the rear sprocket housing on the wheel,, may have a bit of wear in it,, or the chain haz a stiff link in the line,, and needs more oiling,, if the chain is dry ,and right now in salty conditions it will be, then that will cause chain slap,,,
Jan 21, 2009 | 1987 Honda CBX 250
Chain tight spot
BUT adjusted like that there's a tight spot with 0mm. The green new chain required gauge on swinging arm tells me there's plenty of life left in the O ring chain. I've done approx 7K miles and chain wasn't new when I got the bike about 15 months ago. The sprockets are not BADLY worn. I fitted a Scottoiler 7 or 8 hundred miles ago..........Do you folks think I need a new chain and sprockets? This tight spot has only very recently become evident - don't think I've damaged the chain but maybe I have. Think I'm talking myself into new chain here!..............Anyone got advice about cheap/good value UK suppliers? Could do the job myself I thinkIf the tight spot is bad enough you will need to replace. And you MUST do it as a set...chain and sprockets. It is a waste of money to just replace the chain because the worn sprockets will wear it out in no time. And do not cheap out on the chain. Make sure you get a good quality O or X- Ring chain. I know the popular thing to do with sprockets is to get Aluminum to save weight, but I'd get the steel. It may weigh more but it will last twice as long. Just re-read, if it is adjusted to spec and the tight spot has no freeplay, yeah, time to replace.,,,
Nov 10, 2008 | 2007 HM CRM F450RR I
Homelite ZR10926 16 Chain Saw Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
