Question about Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129
My Shimano Alvio 3-speed front shifter has
My Shimano Alvio rapid-fire 3-speed front shifter has developed an extremely long throw that is painful on the thumb to shift. Is there an adjustment to shorten the throw? Is it just a matter of tightening the cable?
    Sergeant:
  • 170 Answers
Rough guess, from past life of bmx.
there should be a cable that runs down to the mechanism, the cable is secured by a small nut, loosen the nut and pull the cable a little more out of the nut with pliers. tighten the nut, and try the linkage.
the shift cable stretches over time and your actually gonna make a small adjustment to compensate for the stretch. by just pulling the cable thru the locking nut to make it shorter.
Posted on Jul 31, 2010
How to instal front gear cable trigger shifter on a womens 7.2 fx bicycle
Does this Trek model have the Shimano EF51, E-Z Fire 8 speed shifter fitted?
Are you replacing it?
Jun 16, 2013 | Cycling
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Is this derailleur 3 speed?
No, it is a front derailleur, and must be able to accomodate 3 front chainrings. Where did you get the derailleur, from what bike? They are not universal fit. A lot depends on your shifter to work and the size of your frame.
Sep 18, 2010 | Mountain Shimano 050 Front Bike Derailleur...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
7 speed alivo shifter no down shift
Hi log onto shimano.com and you will find what you are looking for
Oct 15, 2009 | Mountain Shimano Alivio Front Bike...
Choosing bike's gearshifter
You must replace your shifter with one that is the same type, that is, if it is a six-speed shifter, you must replace it with a six-speed shifter. Also, if you have a Shimano derailleur, then the shifter you get must be a compatible type. Shimano uses a 2:1 actuation ratio, so you have to use a Shimano shifter or a SRAM 2:1 shifter (Attack, Centera or MRX models).
The only stupid questions are the ones we don't ask, friend. Look on eBay under bicycles for "6-speed shifter" and you will be able to find some really good deals.
When it comes time to work on your bike, go to Park Tool's website (parktool.com) and on the top right corner is a "Repair Help" link. You can select your topic by highlighting the part in question on the bike.
Hope this helps,
matt
Aug 23, 2009 | Cycling
Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129 Logo
292 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
john h
Marvin
Marvin
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
