Question about Cameras
Hi, after switching off the cam, I get a message saying ''lens error''. When I turn on I also hear strange ''bzz'' from the lens. How can I solve it? I've tried turn off and remove the battery but the problem remains ... What can I do? What is the problem? Thanks Carla
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 31, 2010
Lens error and green light flashing
Greetings,
power related issue.
check your batteries - charge or new
fxnlogo_s.png Technical Support, Instructions & Repair Service
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Says-please turn camara off and then on again...........doesnt stop getting same message
Sorry you have to get it serviced.... (1) Usually this type of message comes when the there is a lens error that means lens does not retracts.. the main reason could be that the motor has stop functioning or the lens is stucking somewhere... Light tapping near the lens may help you... Or (2) your current battery has exhausted the whole life, then this case the inserting the new battery will solve the problem.....or (3)in the rare case the cam's firmware has been corrupted...
Hope this has helped you... Please rate the answer... Thanks..
Jun 15, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a nikkon D90 .The problem is it takes a few pictures then it locks up with an error of F-- and also sometimes with some type of strange mark with 33 number behind it .Why does it do this alot,hope...
According to the Nikon Support Webpage:
The F-- error message is indicating the camera and lens are not communicating. Either the lens is not designed with electronic contacts, or maybe the lens is not connected fully and clicked in to place. Make sure if the lens is a CPU lens, that it is completely connected onto the cameras bayonet lens mount. You will hear a "click" when the lens is locked in place.
If you have other questions about your Nikon product, you can look up answers here:
http://support.nikontech.com/app/answers/list/p/19
I hope this helps and good luck!
Nov 12, 2009 | Nikon DSLR D90 Digital Camera
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Jul 05, 2009 | Casio Exilim EX-Z77 Digital Camera
HI. Every I attempt to take a picture with my cam, I get a "Error 01" message. Please advise. Thank you
Err 01: LENS COMMUNICATION DESCRIPTION: This error occurs in the following conditions: When electronic communication with the lens cannot be established, after the EOS D300D is powered ON or when the shutter button is pressed halfway. When the lens diaphragm cannot be controlled during shutter release.
REMEDIAL MEASURE: Clean the electronic contacts on the lens with a clean, soft, dry cloth and check the mount interface switch on the body's lens mount for dirt or other damage. If this does not solve the problem, try another Canon EF lens or have the EOS EOS D300D examined by a qualified service technician. This error is similar to Error 84 on the D30.
rate me on this one...
thanks!
May 09, 2009 | Canon EOS 40D Digital Camera
Error message
try Klomtrix trick this worked with my camera thanks klomtrix
Oct 25, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
Cannot take pictures / lens does not retract
when it makes the noise like it's trying to focus and then beeps and shuts off you need to send it into casio to have it fixed. That sound you are describing sounds like what they call "lens error". Contact their repairs dept and they will give you a good idea of what it would cost to fix it and the closest place you can send it.
Jul 02, 2007 | Casio Exilim EX-S500 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
