Question about Canon imageRUNNER C3220 Color Copier
What is the min. and max cost of a fuser unit replacement??
I need the cost of labor, part or parts cost,and time my machine will be down. And how much would it cost to get it fixed on the weekend???
  • Canon Expert
  • 1,326 Answers
It all depends where the copier is? I work on weekends. I'm in NJ, where are you?
Posted on Aug 01, 2010
I have very bad print quality down the middle of the page...appears to be shadowy repeating images. I have replaced the toner and tried to see if anything needed to be cleaned out, but none of that has...
Most likely this is being caused by the fuser. More specifically the fuser film. The fuser is the part that gets hot and "fuses" the toner onto the paper. When the film, which is a non-stick material starts to go bad a small amount of the toner "sticks" to the film and is then re-applied to the paper in a much lighter form a couple of inches down the page. Depending on what your local service options are you can have someone come out and install a new fuser film onto your existing fuser unit. This is the solution I use most for my customers. The cost is around $150 to $180 for parts and labor. A new fuser, which you could install yourself is around $225 to $250 depending on your sources. You can order these online pretty reasonable. Just do a search for HP 4240 fuser unit.
Since you have already tried the toner cartridge then 95% sure the problem is in the fuser.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 27, 2011 | HP LaserJet 4240n Printer
Sir, i have Konica 7145 machine. i have any 10 mints after F-35-3 error, or some time F-35-9 eroor
Hi the error codes you are getting f-35-9 and f-35-3 are common error codes for this machine
First do not reset the machine using 25 dipswitch 3-1 until you resolve what is wrong
The errors are related to the fuser unit assembly parts f-35-3 is the th1 thermistor f35-9 is also an issue with th1
I can tell you that the thermistors th1 and th2 have been changed a nuber of years ago you will need to replace them both also any other parts in the fuser like the web upper and lower clas adn rollers busings ect there is a fuser kit that you can purchase from konica it comes with all the parts to replace on the fuser unit
when replacing the parts on the fuser unit this must be done by a certified technician only if you are not trained to do this leave it alone
The best option is to replace the fuser unit assembly and have it installed by a certified engineer you will save a lot on labour
Once the new unit or refurb unit is done you will need to switch of machine hold down 2 and 5 at the same time switch on the machine and then go into dipswitch 3-1 and change from 1 to 0
Jan 20, 2011 | Konica Minolta Office Equipment & Supplies
Help! My printer is printing text and then leaving like a shadow or very light imprint of that text on other pages. Too, there are a few ink splotches here and there on the various pages. Does the printer...
First, if you have one available swap out the toner cartridge. It is possible on this series for the toner cartridge to cause double imaging. This is especially true if the double imaging is across the entire page. If the double imaging is in more of a streak or line down the page especially on one edge then is it more likely to be a fuser film going bad. You can replace the fusing unit yourself if you want. Just do a google search for HP 4350 fuser unit (going by the picture in your post)
About $150 to $200
If you can find a guy, you can have just the fuser film replaced in your fuser unit at a cost of around $175 for parts and labor.
The most expensive route is to have a service company replace the fuser. They will charge you around $300 parts and labor.
Jul 07, 2010 | HP LaserJet 4250n Printer
Printer has a 1/2 inch 'tire tread' mark at the
This is almost always caused by the fuser unit. If you have a spare toner cartridge then check that first. Most likely tho it is the fusing unit. You can find these online and they are easy to change. If you must hire someone to do it then see if you can find a local tech or company that will replace the fuser film, not the whole fuser. Fuser Unit replacement with labor is going to cost you somewhere in the area of $300.00. If you can find an honest person they can just replace the fuser film for around $100. The fuser film is the only part causing the left edge marks.
Jun 22, 2010 | HP LaserJet 4100n Printer
I have a continous smudge on the right side of the page when printing on a 2420dn. I have replaced the cartridge with no success.
Your Fuser Film is the most likely cause. These do more often than not, fail prior to the fusing unit needing to be replaced. The test for this is to print a page then shut the printer off when the page is about 1/2 way thru the printer. Just kind of time it from the time it feeds the paper to when the paper exits the printer. Cut this time in half and use that as a guide to when to shut the printer off. Once you do this open up the printer where the toner cartridge is and remove the cartridge. If the page is about 1/2 printed then look at the edge where the smudge usually is. If it is not there then you know it is the fuser. You can either order in a new fuser unit or see if a local repair company will do just a fuser film for you. This is what I do. The fuser film plus labor is about $100.00
The fuser unit plus labor is around $250
Also if the fuser is at fault you will sometimes see part of the image from the top part of the page will get reprinted farther down the page in the area where the smudge is.
May 20, 2010 | HP LaserJet 2420 Printer
The oven light turns on and makes noise but it does not produce any heat. My cup of water that was in there for 3 mins was still cold. If I did not actually touch the water though I would not have known...
The megatron tube is out on the machine. Typically, if the unit is still not under warranty it is best to replace the unit. The parts/labor cost involved do not make it cost effective to repair the units. Also, you get a new warranty!
Nov 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
Jul 24, 2008 | Brother International Plain Paper Fax
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
Canon imageRUNNER C3220 Color Copier Logo
117 people viewed this question
old marine
old marine
