Question about Sharp AR-M205 Copier
Cannot scan in color. can only scan in gray. - Sharp AR-M205 Copier
  • Sharp Expert
  • 1,326 Answers
That is because it is a Black or White copier. It will not scan in color, it is not designed too
Posted on Aug 01, 2010
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
How do I get my HP Desktop Printer 3050A to scan full 8.5''x11''?
Hi Joe,
Do do not select Paper type or Paper size for Scanning. Set the preferences to Auto or Default and Scan it.
Regards,
Sean
Apr 09, 2013 | HP Deskjet 3050A J611G Inkjet...
How do I scan 35 mm slides on my C3180 all in one printer/scanner?
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Gray
Check the scanner settings in Captureperfect. Try scanning in color by selecting color mode. If it works then there is no Hardware issue.
S. Mohan
Sep 04, 2008 | Canon DR-9080C Path-Through Scanner
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Scanner
You may check the details below.
Internal Scan Depth: 16.7 Million Colors (24-bit),256 Gray Shades (8-bit)
Max Scan Resolution: 4800 x 4800
Optical Scan Resolution: 600 x 600
You may refer to the link
http://computers.pricegrabber.com/printers/m/11922472/details/
Nov 29, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Sharp AR-M205 Copier Logo
63 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
