Question about Marzocchi 2008 XC 700 ATA Mountain Bike Fork 100-140mm
I have bought some zoom gordo 660 forks and want to know how to install the front wheel on them
HOW MUCH OIL IN THE FRONT FORKS OF XT660X
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Fork oil change XT660 com The 1 XT660 Resource
YAMAHA 600 xt forks job
Yamaha XT660R Owner Manual
OEM parts for Yamaha
YAMAHA XT660R Service Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 12, 2012 | 2004 Yamaha XT 660 R
2004 Yamaha xt660x fork oil capacity
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.louis.eu/rund-ums-motorrad/bike-datenbank/yamaha-xt-660-x/dm011/1176
Yamaha XT660R 2004 Service Manual
Jan 31, 2012 | 2004 Yamaha XT 660 X
I have just bought a new SCHWINN CORONADO WOMAN BIKE and i'm trying to assemble it. The distance between the fork dropoouts is bigger than the front wheel axis. The only possible assembly of the front...
When you tighten the quick-release skewer, the two sides of the fork will be pushed inwards over the axle. So basically, just tighten it up & it should be just fine. If not- take it back to the store you got it from!
Oct 30, 2011 | Schwinn Coronado Women's 26" Alloy Frame...
We just bought a womens lakeshore 26" and the assembly instructions are terrible. How do you affix the front wheel?
The front wheel axle fits into the fork, there is a U shaped notch in each fork leg at the end of the fork. There are two washers with bent tangs on them that fit into holes just above where the axle fits into the fork. Slide the washers onto the axle, one on each side. the tangs on the washers should fit into the small holes above each U shaped notch that the axle is in. Next screw on the nuts supplied for the fork. The tire should be centered between the fork legs before you tighten the nuts to secure the front wheel to the fork.
Aug 17, 2010 | Schwinn Cycling
I bought a set of forks and I can't get old forks off from axle. Do I have to remove axle bolt?
Yes you have to remove the axle bolt. Both forks can slide out individually.
Make sure you have removed the front wheel, brake calipers and the front fender. There is a brace too that needs to be removed or loosened. And make sure the triple tree is loosened too so they can slide. When you install the new ones make sure they go back in the same spot as the old ones or it can make your bike ride unsafe.
Dec 01, 2009 | 2003 kawasaki ZX-6R
Cannot fit to my Trek 820 due to
You have to use a different fork. There are three standard steering tube sizes: 1"; 1.125"; 1.5". The 1" is found on budget bikes, older bikes and some cruiser/hybrid bikes. 1.125" is the most common size and is also usable on 1.5" head tubed bikes using reducing headsets. 1.5" is found on heavy-duty mountain bikes and some carbon fiber road bikes, although its use is increasing in popularity.
The point is, you can sometimes convert down, but never up. You have to source a different fork.
Sorry, mate
matthew
Nov 01, 2009 | Cycling
Tires I bought are too thick to fit in between my forks
sure you can get new forks just make sure the inside width of the forks will hold your tire and that the radius of the wheel from the axle to the outer edge is smaller than the inside length of the forks
Aug 31, 2009 | Dynacraft Girls 16" Barbie Bike
Replacing the front seal- located on the fork.
To replace the fork seal you must open the top of the fork and remove the spring. Then drop the fork tube out of the clamp. Once the fork tube is removed replacing the seal is simply pulling the old one off and putting the new one on. You will need to remove your front wheel.
Jun 29, 2009 | 2003 Yamaha YZF 600 R thunder cat
Zoom gordo 660 forks rock hard want to adjust no manual
must have been stood a long time seized solid.took out of clamps turned upside down ran thin oil into seals put full weight onto each fork one at atime and gradually got them moving now perfect.
Mar 23, 2009 | Cycling
Bicycle Fork Installation
remove front wheel
undo allen screw or bolt securing headstem to fork
remove headstem and handlebars
undo lock nut & ring retaining bearings, at top of fork tube, do not lose bearings which may be loose.
withdraw fork from fork tube, do not lose upper bearing race
remove lower bearing from old fork
install lower bearing on new fork (I prefer replacing bearings)
remove brake caliper from old fork install on new fork
insert fork in fork tube
install upper bearing (I prefer replacing bearings)
install retaining ring and lock nut on fork tube, adust untill there is no wobble, but free movement, too tight the bearings will collapse too loose the rider will fall off
tighten lock nut
install headstem
tighten headstem allen key - bolt
install front wheel
Oct 29, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
Marzocchi 2008  XC 700 ATA Mountain Bike Fork 100-140mm Logo
646 people viewed this question
Top Marzocchi Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Marzocchi Cycling Expert? Answer questions, earn points and help others
