Question about House Brand Aqua-Pure AP102T Whole House Water Filter System
My sistem model is 268/760 the ring to tight the tank and motor is crak,it is leaking,where i can buy tis part
How to install a fuel pump
REMOVAL & INSTALLATION
CAUTION
Fuel injection systems remain under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. If equipped with air suspension, the air suspension switch, located on the right-hand side of the luggage compartment, must be turned to the OFF position before raising the vehicle.
  2. Disconnect the negative battery cable.
  3. Relieve fuel system pressure using the recommended procedure.
  4. Raise and safely support the vehicle.
  5. Remove the fuel tank from the vehicle and place on a suitable work bench.
  6. Remove any dirt that has accumulated around the fuel pump retaining flange so it will not enter the tank during pump removal and installation.
  7. On 1989-94 models, turn the fuel pump locking ring counterclockwise and remove the locking ring.
  8. On 1995-98 models, remove 6 retaining bolts around the perimeter of the fuel pump module.
  9. Remove the fuel pump/sending unit assembly. Remove and discard the seal ring.
To install:
  1. Clean the fuel pump mounting flange, fuel tank mounting surface and seal ring groove.
  2. Apply a light coating of grease on a new seal ring to hold it in place during assembly and install in the seal ring groove.
  3. Install the fuel pump/sending unit assembly carefully to ensure the filter is not damaged. Make sure the locating keys are in the keyways and the seal ring remains in the groove.
  4. Hold the pump assembly in place and install the locking ring finger-tight. Make sure all the locking tabs are under the tank lock ring tabs.
  5. Rotate the locking ring clockwise until the ring is against the stops.
  6. Install the fuel tank into the vehicle.
  7. Lower the vehicle.
  8. If equipped with air suspension, turn the air suspension switch to the ON position.
  9. Add a minimum of 10 gallons of fuel to the tank and check for leaks.
  10. Reconnect the negative battery cable.
  11. Turn the ignition switch to the RUN position several times to pressurize the fuel system. Check for fuel leaks and correct as necessary.
  12. Start the engine and check for leaks.
  13. Road test the vehicle and check for proper operation.
Nov 22, 2015 | 1988 Mercury Grand Marquis
Install 1995 mercury grand marquis fuel pum
CAUTION
To install:
Nov 22, 2015 | 1995 Mercury Grand Marquis
Was wondering if theres a gaskit for the fuel line keeping gas from leaking out where the fuel line exits the tank
Typically the fuel lines have a fat spot with built-in retaining rings that squeeeeeeeze tightly into the plastic fuel tank opening. The fuel lines are easily destroyed during removal and easily damaged during installation... Be sure to coat the swelled up portion liberally with oil while reinstalling....or get ready to buy another one if available.
Oct 05, 2014 | McCulloch Bar Bolt Mac Cat Titan 7 355 365...
Was driving and my car died. it does not want to start.where is the electric fuel pump at?
Electric Fuel Pump REMOVAL & INSTALLATION CAUTION
  1. If equipped with air suspension, the air suspension switch, located on a side panel of the trunk compartment, must be turned to the OFF position before raising the vehicle.
  7. On 1988-94 models, turn the fuel pump locking ring counterclockwise and remove the locking ring.
  8. On 1995-00 models, remove the retaining bolts around the perimeter of the fuel pump module.
  9. Remove the fuel pump/sending unit assembly. Remove and discard the seal ring. To install:
  10. Clean the fuel pump mounting flange, fuel tank mounting surface and seal ring groove.
  11. Apply a light coating of grease on a new seal ring to hold it in place during assembly and install it in the seal ring groove.
  12. Install the fuel pump/sending unit assembly carefully to ensure the filter is not damaged. Make sure the locating keys are in the keyways and the seal ring remains in the groove.
  13. Hold the pump assembly in place and install the locking ring finger-tight. Make sure all the locking tabs are under the tank lock ring tabs.
  14. Rotate the locking ring clockwise until the ring is against the stops.
  15. Install the fuel tank into the vehicle.
  16. Lower the vehicle.
  17. If equipped with air suspension, turn the air suspension switch to the ON position.
  18. Add a minimum of 10 gallons of fuel to the tank and check for leaks.
  19. Reconnect the negative battery cable.
  20. Turn the ignition switch to the RUN position several times to pressurize the fuel system. Check for fuel leaks and correct as necessary.
  21. Start the engine and check for leaks.
  22. Road test the vehicle and check for proper operation. Fig. 1: The fuel pump is located in the fuel tank. On some models it can be viewed from the side as shown here 89605p02.jpg
    Fig. 2: Electric fuel pump removal 84175037.gif
    Fig. 3: Fuel pump locking ring installation 84175038.gif
Nov 18, 2010 | 1988 Lincoln Town Car
Need a diagram on fuel pump installation
CAUTION
    fuel pump module.
    ring.
    To install:
    ring groove.
    ON
    position.
Nov 03, 2010 | 1996 Lincoln Mark VIII
How to change a fuel pump
Ford Crown Victoria/Grand Marquis 1989-1998
Electric Fuel Pump - REMOVAL & INSTALLATION
CAUTION Fuel injection systems remain under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
To install:
See Figures 1, 2 and 3
Hope this hel to solve your problem (remembercomment and rated this).
Apr 25, 2010 | 1992 Mercury Grand Marquis
HOW DO CHANGE A FUEL PUMP ON A 93 LINCOLN MARK 8
Removal & Installation See fuel pump under fuel tank in this section.
  7. On 1988–94 models, turn the fuel pump locking ring counterclockwise and remove the locking ring.
  8. On 1995–00 models, remove the retaining bolts around the perimeter of the fuel pump module.
To install:
  2. Apply a light coating of grease on a new seal ring to hold it in place during assembly and install it in the seal ring groove.
Oct 13, 2009 | 1993 Lincoln Mark VIII
Fuel leaking around device on top of motor
does it look like a long bar? if so, check to see if fuel lines are tight. you have 2 fuel lines 1 is a supply from the tank the other is a return to the tank. also fuel injecter O rings have a tendency to leak over time.. chevrolet caverliers are bad for this
Jun 30, 2009 | 2001 Pontiac Grand Am SE
Took tank off and reinstalled 9 times - put new gaskets and rings in - but it leaks. Tank also wiggles a bit.
Go to the hardware store and get a tube of plumber's grease. Then grease up the gaskets and the rubber ring. Snug everything down and if it leaks snug it down a bit more
Apr 26, 2009 | Home
remember you are messing with gas.so no fire,sparks and smoking allowed around car.dissconnect neg. on battery.then relieve fuel pressure by taking off gas cap.take all gas out of tank.undo fuel neck,both straps,hoses and any electrical conectors.take take out from under car.remove any dirt or debri from around fuel pump.there is a locking ring that needs to turn counterclockwise.remove fuel pump and bracket assembly.discard seal.clean pump flange,surface and seal ring groove.apply a light coat of grease to seal to hold in place during install.put seal in ring groove.install fuel pump and bracket carfully to ensure filter dont get damaged.make sure the locating keys are in keyways and seal stays in groove.hold pump in place and install locking ring finger-tight.make sure locking tabs are under the tank lock ring tabs.rotate lock ring clockwise intill it stops fully.put tank back in car.make sure all connections and lines are tight.put only 10gals in tank and check for leaks.put a fuel pressure gauge on the valve on the fuel rail.turn ignition on,but dont start.turn ignition on for 3 seconds then back to off.repeat this 5-10 times or until pressure is at 35psi.if you dont get 35psi or it drops back down check for leaks.if it stays at 35psi then remove fuel pressure gauge and start car.while running check for leaks.this is directly from ford motor co.verbatom.good luck.
Apr 01, 2009 | 1994 Mercury Cougar
House Brand Aqua-Pure AP102T Whole House Water Filter System Logo
66 people viewed this question
Top House Brand Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a House Brand Garden Expert? Answer questions, earn points and help others
