Question about Opti -UPS PowerES 650 UPS System
We have a faulty MGE 60 KVA UPS and would like to know a repair company in the preston lancashire area. Thanks
    Genius:
  • 1,689 Answers
Most of the failures with these are the batteries. Contact the manufacture for details about having it serviced in your area. They should have the contact information in their instruction manual that came with the unit.
Jerry G.
Posted on Apr 24, 2008
What coolant liquid use the MGE Galaxy 3000 UPS System 10 kva
What????? No coolant liquid is ever used in any type of UPS. EVER
Sep 04, 2014 | MGE Galaxy 3000 UPS System
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
Mi ups no arranca sin abterias y conectado a la red electrica
Ruben,
MGE que clase? kVA? Voltage? Que es Red? Se un poco de UPS per no entiendo que es abterias y red electrica. I can help you if you help me.
Jan 13, 2014 | MGE Computers & Internet
MGE S3000 overload and continous beep
Remove some load from the UPS output.
Need more info. How long have you ran it with the load prior to the overload. In other words, what is the total kVA now and what is the kVA when it was running normal? Also what time is this overload happing? Need to get the code and look for the sticker on the inside of you UPS to identify the alarm. Past experience I came across were people (Cleaners or the employees) will connect heaters, vacuums to the outlets and this will cause the overload.
Jan 07, 2014 | Computers & Internet
Circuit diagram
all MGE UPS systems below 15 KVA is a part of EATON long ago
Sep 26, 2013 | MGE UPS Pulsar Ellipse 500 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
My ups is switching off itself immediately the mains goes off.the battery is okay with 13v.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and enviromental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only a float voltage and a true indication of the battery voltage needs the batteries to be tested under a load. there maybe one battery that is faulty and causing the whole battery system to fail.
These lower powered and cheaper KVA type UPS are switch over types (when the mains fail, the UPS switches over to the inverter in milli-seconds to supply mains power). It is a possibility the inverter circuit is faulty and when the mains power fails the inverter does not switch over.
The true UPS type are usually the higher KVA units (over 1500 KVA units) that converts mains power continuously via the inverter circuit. The mains power charges the batteries and the inverter drawing power from continuously from the batteries (therefore there is no switch over time lag from the mains to the battery.
Sep 25, 2009 | MGE Pulsar Ellipse 800 (89363) UPS System
Opti -UPS PowerES 650 UPS System Logo
90 people viewed this question
Top Opti Computers & Internet Experts
David Payne
David Payne
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
