Question about BenQ T701 TFT 17" LCD Monitor
Benq fp767 backlight problem
Hi, to all
i have a benq fp767 monitor that when i turn it on it works perfectly for 1 or 2 seconds then it becomes black and after some seconds it flashes for a 1 seccond then black again, and every timer i turn the monitor off then on it does the same thing. the green led is on and i can see the picture so its a backlight problem, i test the 4 c5707 and the 2fu9024n they are all ok. now i dont know what to do and what to check else please help me to repair it.
thanks to all helpers
I've repaired my FP767 just today. It had similar problem.
First of all I thought that I needed to replace CCFL tubes.
Then I noticed inflated capacitors in power supply.
I replaced them all and monitor works as new.
Posted on May 17, 2008
    Genius:
  • 1,689 Answers
You can try contacting the manufacture or their distributor for service information. Most of the time, these monitors are not feasible to service. In many of these models, the backplane lamps are not able to be changed because of the way the screen is constructed. Very often, the backplane lamp supply also has to be changed along with the lamps.
Start here for Benq service support:
http://www.benq.com/support/
By-the-way, from my past experience, Benq, as like the other monitor manufactures will not sell service manuals, or spare parts directly. They will tell you that you have to send the monitor for service.
Jerry G.
Posted on Apr 24, 2008
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
FP767-v2 - 17" LCD Monitor: when you turn it on benq flashes on the screen...
Check the cable on your monitor through video card if there is loose connection. Check also the video card by replacing it with your extra video card if you have. I think the problem is not the monitor but the video card.
May 18, 2010 | BenQ FP767-v2 - 17" LCD Monitor
No backlight in Benq fp767-12 I have replaced all c5707 on inverter board and fu9024n and few capacitors but it still does not work
If you can expose it, examine the ends of the fluorescent tube itself; if there are prominent black rings at the end, the tube is toast. These cost much less to replace and live only about 4-5,000 hours, much shorter than the inverter board usually lasts. You can buy these from several US sources; the one I recently used was great and the part was $10:
CCFL Warehouse
Mar 06, 2010 | BenQ FP767-12 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
How to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Jun 13, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem
IT seems you are not technically trained in electronics.In this case it's difficult to explain via this board,Best you find someone to fix it for you,you can try contacting Benq Support locally.
Sorry for not being able to help.
Samir
Jun 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem - Power LED Blinks
Look for small power transistors 2SC5707 near yellow invertor transformers which go to backlight connectors.
But if problem is blinking power LED powersupply capacitors maybe an issue,check visualy and/or replacement.
Also fuse that maybe blown is not glass fuse near mains socket,It is semiconductor black or yellow colour labeled PFxxx near heatsinks of power supply secondary.
Please rate the solution and provide feedback.
Samir
May 25, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
667 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
