Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna 324l what weight of oil and how much oil
... what weight of oil and how much oil for oil change?
2 Suggested Answers
  • 15 Answers
SOURCE: husqvarna 324L 4 stroke, runs fine, but leaks gas, from carb whil
gasket is worn out. You can buy a generic gasket set from your local lawn shop
Posted on May 31, 2010
Husqvarna 324L has a floppy choke. What should I do?
To properly repair,, it may require a carburetor replacement. To my knowledge individual parts for the carb is not available.
Jun 25, 2017 | Husqvarna Garden
Craftsman 27 13.5. What type of oil should I use?
SAE30.... Always...
10/30 will work as well.... you can find 30 weight in Home Depot or Lowes..
All engines on riding mowers take 30 weight oil... Cub Cadet, Husqvarna, Craftsman... anythinges up to 25hp
Nov 01, 2015 | Garden
Model 324L-x. Why does it lose power at full throttle?
Adjustment on the H needle is needed...
If the unit ever bogs on full throttle , or seems to struggle then you have to adjust the High.
You do this by holding down the throttle as you turn the needle. If you have the plastic red and white covers on the needles , you can take em right off...
Oct 15, 2015 | Husqvarna Garden
I changed the oil on my husqvarna riding mower now it it only riding vey slow
Did you use the correct oil weight? Oil drip down onto drive belt and it's now slipping?
Aug 28, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a husqvarna 435 and its not oiling, is there an adjustment skrew anywhere? thanks
There is no oil adjustment on the 435 and these saws have bad oiling systems( leak oil badly when not is use and don't put out enough when running) , bad enough that it damages the bar and chain. The only solution is to use 30 weight engine oil ( bar oil is to thick). Crummy design.
Jan 27, 2012 | Husqvarna Garden
Husqvarna 324L 4 stroke, runs fine, but leaks gas, from carb whil
May 29, 2010 | Husqvarna 28cc Gas Line Trimmer
What weight motor oil do I put in?
lift hood you will specks usually under hood or around in that area I usually use a good brand 30w oil
Apr 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna 28cc Gas Line Trimmer Logo
752 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
