Question about Sony Playstation 3 (PS3) Console
I am trying to open up my ports on my wireless router i have WRT 54G Router and PS3 is saying that I have NAT 3 and i need to convert it to a NAT 2. I know where the ports are on the router but i am not sure what port numbers to put and the UDP AND TCP and what order they go. Sony said 50 to 12000 udp and tcp
    Problem Solver:
  • 5 Answers
Well first of all, you need to convert from NAT 3 to NAT 2. the only difference between the two are that NAT 3 doesn't have UPNP. NAT 2 does.
Posted on Apr 25, 2008
Hi i would like to change the NAT settings for my PS3 i have a st585v6 router how can i do this. the ps3 is not wireless
hello,
To change the NAT settings you need to open ports on the router. For that
1)Get the TCP/UDP ports from PS3 vendor
2)Get the IP add of your PS3
3)Log into the router interface and open ports for it.
Hope this helped.
Jan 21, 2011 | Computers & Internet
How to get your NAT type from strict to open for a ps3. i have tried opening the ports on the router. it still does not change the NAT type
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Dec 06, 2009 | Linksys Wireless-G WRT54G Router
How to get nat 1 netopia router 3347 ps3
  • you need to access the router access page of the router, look at the bottom for router access page or call router support
  • then go to WAN setup to enable/disable NAT
Aug 11, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
May 05, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Im using vuze torrent downloader,i have a nat problem
It seems like you have 2 Different Issues ...
1 ) Low Speed on Vuze Downloads
2 ) NAT 2 On PS3
TO REDUCE THE NAT ON PS3
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3
Step 7: Get the IP Address of the PS3
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3 in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Apr 10, 2009 | Belkin (54G F5D7230UK4) Wireless Router
I had bought a wireless router today
You need to do port forwarding. Port forwarding will open your NAT type to 1. Just call Sony and ask what port should you open on your router's admin page.
Apr 01, 2009 | NetGear WGB511 802.11G Wireless...
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Sony Playstation 3 (PS3) Console Logo
201 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
