Question about Refrigerators
KSC525IN5500 refrigerator, icemaker would not fill, changed the water valve, it fills, and now just wont dump, can you help?
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Make sure the freezer is at least 17 degrees or colder more colder is better. If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face don't turn just press. That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad broken gear. Make sure there's no "alien" object that got clogged onto the ice dispenser itself. There's also a small heating element under the ice tray. I wonder if that element is not warming the bottom of the tray to allow ice to dump. If that happened, didn't warm the tray, it may have caused the plastic piece to break.
Thank You for contacting Fixya and please accept the solution if it has helped you.
Posted on Jul 31, 2010
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
I have a kenmore refrigerator that the icemaker wont make ice. i have swapped the icemaker out with a new one and i have checked the vavle in the back by swapping sides with the water dispencer and it...
wait, you say you swapped the sides of the water valve? so am i to understand that you took the water line that went to the icemaker fill tube, took that out of the valve, and placed it into the solenoid for the water dispenser? that wont tell you if your ICEMAKER solenoid is bad, it only proves that your water dispenser solenoid is good.
if i had to guess, you have a bad dual water valve
Feb 19, 2010 | Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is not making ice, help?
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Icemaker (whirlpool)
i suggest you replace icemaker.it is sending signal to water valve.
Jun 22, 2007 | Hotpoint  15.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
