Question about Legacy LMR15.1 Roof Monitor
My monitor screen continues to read no signal. I press all the buttons, and the only change is from AV1 to AV2.
ON THE VERY TOP OF SCREEN, I HAVE LINE WITH "NO SIGNAL" ON LEFT SIDE AND A NUMBER 3 ON THE RIGHT SIDE. ANY SUGGESTIONS
You might just need to press the source button on TV remote so a box pops up on the screen giving you options like tv,hdmi1,hdmi2 or av1,av2. Hopefully its a little helpful.
May 30, 2015 | Sony BRAVIA KDL-46S2010 46" LCD TV
I was av1, av2 before but now i can't access my lg 42'' flat screen A2
Hi happy,
This happens quite often due to current leakage from signal box.. Please continue with AV1. But Have your cable box or whatever signal box you are using for any current leakage so that AV1 remains safe. If you lose AV1 too, you may have to replace the main board.
May 07, 2015 | LG Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
I accidentally hit a button the remote near the
hello on the remote control it should say tv if you press it .it should take you back to normal view . or if you keep pressing that button and go through all the channels it should bring you back to normal tv
regards
shaun
Jan 20, 2010 | Televison & Video
Lost the remote
that one is easy just press menu the channel button up till you get to av1 or av2 then press the volume to change it.
Dec 12, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision GX-1581 No Signal
It looks like you've narrowed it down to a settings issue. If it is saying "No Signal" while on AV2, then you need to switch to AV1 where your video signal is. A remote might be available online from XO Vision (www.xovision.com) directly or on E-bay. You might also be able to find a local dealer of XO Vision from their website. One quick fix you can try....since the monitor has 2 video inputs and is stuck on AV2, you can simply get video by unplugging the video input on AV1 and plugging it into AV2. Hope this was helpful.
Sep 27, 2008 | XO Vision GX828 8" Roof Mount TFT LCD...
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Legacy LMR15.1 Roof Monitor Logo
26 people viewed this question
Top Legacy Car Audio & Video Experts
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
