Check to be sure you are using the correct washer for the center mounting hole that fits around the center mounting bolt, and inside the universal mounting center hole of the blade and as well be sure that you use the washer that covers the inner spacer washer as well that secures the blade to a solid mounting that won't vibrate ( large washer on the center mount bolt First then the smaller washer that fits into the blades mounting hole and over the bolt )
