Question about Delta 10"Hybrid Tablesaw with 30"Unifence
The motor on my Delta 36-600 table saw started smelling funny and tripping it's breaker while I was using the dado blade. It ran for a while after re-starting but then started bogging down, and then quit running all together. I've had it for probably 10 years and it has had a lot of use. I have never changed the brushes. Do you think that could be the problem or is it something else?
efs_perpends
  • 1996 Answers
SOURCE: Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Posted on Mar 24, 2009
  • 384 Answers
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Posted on Sep 15, 2009
  • 384 Answers
SOURCE: where can i buy a new motor for delta table saw
Buy the motor from Sears, Tractor Supplies, Northern Tool, some large ACE stores, and some home improvement stores.
Posted on Sep 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Posted on Dec 08, 2009
SOURCE: I have a delta 36-600
In my Delta table saw the motor and blade turns but it can't cut even MDF, the blade stops as motor runs super strong. It seems to be a clutch problem but I am not sure other parts such as belt, gears or ... involved. I appreciate any help.
Posted on Aug 21, 2011
MY ROCKWELL 10 INCH TABLESAW SUDDENLY QUIT WORKING. IT TRIES TO COME ON WHEN I HIT THE START BUTTON, BUT BLADE TURNS 1/4 INCH THEN STOPS. CONTACTOR STILL HUMS THEN THE BREAKER TRIPS. PLEASE HELP!!
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I inherited an older Delta 10 inch table saw. While cutting lumber the blade slows down and stops. The wood is not binding the blade. With power off the blades and motor turn freely. Does the motor...
Two easy possibilities are that the blade is dull or that the wire is too small. The wire is likely to be a problem if you are using an extension cord. You could move the saw near to an outlet that you know to be wired with 12 gage wire (not 14). Or you could buy as short as possible 12 gage extension cord. If being underwired is the problem, you will notice that the motor comes up to speed much faster when wired adequately. You might also buy a cheap new blade to rule out the dull blade problem. If neither of these fixes the problem, then the motor has become "weak" because it has overheated just enough to cause some minor shorts between the windings. (If the shorts are major it won't turn at all and will trip a breaker.) In this case the motor can be rewound, but it will probably be cheaper and easier to just replace the motor.
Good luck, Al K
Oct 22, 2010 | Delta 36 981 10 Inch Left Tilt 1 1/2...
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
Jun 29, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
I need an instruction manual for my delta shopmaster 10'' bench saw model number TS200LS. I know very little about table saws and need to change the blade and would like to install a dado blade.
you might try Dewaltservicenet.com and type in your model number in the middle of the page under need manual and see if you can find it there if not let me know and I will try and find one for you.
Nov 21, 2009 | Delta Saws
PM2000 tablet saw won't spin up with 3/4" 8" dado stack. Trips overload limit switch.
Check your alignment of the blades, sounds like they are hitting something and will not turn. To check unplug saw and try to turn blades by hand. If they don't turn thats the problem, if they turn check and make sure that the blade is the right type for saw. But if the regular blade works fine you have a binding problem with the dado blades.
Sep 25, 2009 | Powermatic 1792016K 10" 3 HP Model PM2000...
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
141 people viewed this question
Top Delta Saws Experts
Craig Butler
Craig Butler
Ronny Bennett Sr.
Ronny Bennett Sr.
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
