Question about Kenwood KDC-MP228 CD Player
I need to troubleshoot a cd laser assembly tracking system. My player usually plays cds ok but sometimes it will show 'no disc'. Other times it will play a track but will then make a clicking noise and stop playing. This has happened with multiple discs, so the laser reader is okay. When I remove the disc sometimes the laser assembly is half way in the track, instead of being on the inside track. It's a cheap no-name unit, but I'd like to repair it if it's easy to do.
MrLard
  • 94 Answers
SOURCE: cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Posted on May 04, 2007
Eagleeyes
  • 199 Answers
SOURCE: E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
SOURCE: Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Posted on Jun 11, 2008
merle840
  • 113 Answers
SOURCE: Kenwood KDC-119 car stereo problem
sometimes, if you unplug the main radio harness out from the back of the radio-leave it unplugged for about a minute you can reset the electronics that are now locked up- after you plug the harness back in you shoud hear the cd mechanism moving- now press the eject button- if there is no mechanical problem the cd will eject. If it won't you can email me at merle840@aol.com or call me at (908)756-3544 if this helps you please give me a good rating
Posted on Jul 02, 2008
Skipping
HelloThe laser pickup unit [Lens assembly] has the trouble. Either it may be damaged, or accumulated dust particles obstruct the laser beam. Just put in a cleaning disc [this disc can be bought from most of the electronics spare part shops at your town], play it for at least three times. If the fault is due to dirt and dust, this process of cleaning will help you. If not. replace the flat ribbon plastic cable, that connects the laser head assembly to the main board. This cable has carbon tracks, instead of metal wire conductors in it. These tracks are likely to get break, during time, because, this wire have to travel along with the laser head assembly, while it tracks the CD. In most cases, the above said two processes will rectify the problem. If these does not help you, you have to replace the laser head assembly with same type and number. Insist on same type and number, as audio CD player laser assemblys have special chareteristics. OK.
Nov 29, 2011 | Technics Audio Players & Recorders
Getting a whine from CD player
Hi there! i have listed out the parts of cd player(see image). The clamper is a part of the cd tray ejecting mechanism that is under the tray. The pcb is used to power the lens mechanism and the laser you are talking about is a part of the lens mechanism(it uses laser to read the discs). Now tell me where did the tech tell you install the brass string and i will help you out
Mar 06, 2008 | Aiwa JAX-S5 CD Shelf System
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Hello .Sometime does not play track
It is having trouble reading the CD.
Either....Dirty CD. Dirty laser eye. Duff CD. Duff laser unit.
One More Time does not like CDs made on your computer too.
Jul 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Should recorder play cds bought from shop
Yes it should play all cd's - the laser is either dirty or needs replacing assuming it can spin discs ok.
Jun 16, 2008 | Denon CDR-M30 CD Recorder
Kenwood KDC-MP228 CD Player Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
