Question about Sharp UX-B750 Inkjet Fax
I can not receive a fax
The fax mode is on. The date, time, number of rings, fax number and name are correctly entered and it is capable of sending a fax. However when a fax is attempted to be sent back from the other end, the phone does not ring and the transmission goes directly to voicemail.
    President:
  • 567 Answers
Hi there, Fax machines are still in common use today despite the widespread adoption of computers along with their multiple communication tools, including e-mail and social networks. Fax problems can include trouble receiving faxes, dialing issues, faxes not printing and poor print quality. Performing periodic maintenance can help with fax problems. Check any visual indicators for trouble. Many fax machines have a display panel and use it for reporting error messages. Often the messages are in plain text and can be understood without referring to the instruction book. Refer to your fax machine'sI can not receive a fax - mag-glass_10x10.gif instruction manual for any numeric error codes.
  • Step 2.Replace the cables. In particular, replace the telephone line cable that runs from the wall to the fax machine. The plugs can become lame, and the wire itself can break inside, providing no visual indication it's broken.
  • Posted on Jul 31, 2010
    • Hilton Bristol Jul 31, 2010
    • Send a fax and have the receiving party tell you if the quality is poor. Send a second fax to a second respondent to eliminate likely issues with the first respondent's fax machine. If both faxes are reported bad, the problem is with your machine. Try cleaning your fax machine's glass with a soft cloth.
    • Step 4Eliminate reception problems. Take a look at a couple of recent faxes that you have received from different parties, if both are of poor quality, it's possible your fax machine needs maintenance. Replace the ink cartridges first. If only one of the faxes is of poor quality, the problem is likely with the sending fax machine.
    NEED 2 PROGRAM COVER PAGE
    Cover Sheet
    You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
    ? Your name and number must be programmed in order for them to appear
    on the cover sheet (see page 49).
    ? To have the recipient's name appear, you must dial using a Rapid Key or
    Speed Dial number with the name programmed.
    1 Load the document(s).
    • SEND READY will appear in the display.
    • Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
    Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
    • The display will briefly show COVER SHEET MODE ENTERED and then
    revert to SEND READY.
    • To cancel the cover sheet selection, press STOP.
    3 Dial the receiving party and transmit the fax.
    If desired, you can set your fax to automatically send a cover sheet with every
    transmission (you do not have to press COVER SHEET each time). This is
    accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
    explained on page 125.
    Jan 17, 2011 | Sharp FO 5800 Fax
    Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
    Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
    Hope that helps.............
    Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Please can you tell me how to change time and date. thank you. Wendy
    The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
    Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
    1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
    2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
    Start/Enter. The display asks you to choose a date format.
    3. Press Start/Enter.
    4. Press left arrow or right arrow until you find the desired date format, then press
    Start/Enter.
    If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
    The display shows the currently set time and date using the selected date format.
    5. Enter the correct time and date using the number keypad.
    Day = 01~31
    Month = 01~12
    Year = four digits
    Hour = 00~23
    Minute = 00~59
    You can also use left arrow or right arrow to move the cursor under the digit you want
    to correct, then enter a new number.
    6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
    The display shows the time and date you have set, then returns to
    Standby mode.
    06-25-1999 12:30 ('USA' type)
    Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
    How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
    Follow the instructions below to set date and time on printer
    Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
    1. Press Setup .
    2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
    3. Select Date and Time from the Tools menu and then press the OK button.
    4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
    5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
    6. Press the Back button to return to the main menu.
    Follow the steps to solve "Unable to Recieve Fax" Issue
    Basic requirement are..
    1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
    2. Auto Answer should be on
    3. Turn off ECM ( Error Correction Mode )
    Use these steps to change the Rings to Answer setting.
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
    Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
    1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
    2. Try to receive a fax.
    Make sure that ECM is Turned Off ( Error Correction Mode )
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    Try to Receive Fax Now.
    These steps should resolve the issue and you should be able to receive fax
    Thank you for contacting FixYa Team
    * Please rate this solution with Thumbs up and comment to help us improve providing support
    Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
    How do I change the time stamp heading- when I send a fax it shows the wrong month , year, date and time
    1. Press <function> then the "Down Arrow" below the <start> button until [ENTRY MODE] appears.
    2. Press "Right Arrow" below the <start> button until [DATE&TIME SET] appears.
    3. Press "Right Arrow" (current set date will appear).
    4. Enter two digit number for day. (To correct a mistake press "Left Arrow")
    5. Enter a two digit number for the month.
    6. Enter the four digit year.
    7. Enter the two digit number for the hour, then two digit number for the minute.
    8. Press <start/memory> (The display will read [POLL SECURITY])
    9. Press <stop> to exit.
    Mar 11, 2010 | Sharp UX-B750 Inkjet Fax
    Xerox Work Center 657 Will Not Recieve, After Replacing Drum
    Check to see if when he reset the fax reverted back to receive only as a default.
    1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
    2. Select the Answer Mode:
      • Press [1] to select Auto answer, then skip to step 3.
      • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
    3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
      NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
    4. Press [Stop] to return to the Standby mode.
    Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
    I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
    Hi zoaj,
    More then likely you have the fax set up to USE A DIALING PREFIX.
    Therefore it is automatically doing this, regardless of what you input.
    Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
    once that is done, it will no longer automatically add the prefix for you. :)
    I have BOLDED the relevant information below that pertains to this.
    Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
    Thank you,
    Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
    • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
    • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
    The following table describes the Fax Setup Utility tabs:
    On this tab:
    You can:
    Send
    • Enter your name and fax number.
    • Select a maximum send speed and a print quality for outgoing faxes.
    • Choose whether to scan the entire document before dialing the number.
    • Choose whether to use error correction.
    • Select when to print a fax usage report.
    • Select when to print a fax activity report.
    Receive
    • Choose whether you want to print a footer (date, time, and page number) on each page.
    • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
    • Select whether you want to forward a fax or print it, and then forward it.
    Connection/Dialing
    • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
    • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
    • Enter a dialing prefix.
    • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
    • Select a distinctive ring.
    Speed Dial
    Add to, create, or edit the speed dial list.
    Group Speed Dial
    Create a group number and name, and then add phone numbers to the group.
    Oct 11, 2008 | Lexmark Office Equipment & Supplies
    Set up to receive fax
    To select or change your Receive Mode
    If it is not illuminated in green, press (Fax).
    2 Press Menu/Set, 0, 1.
    3 Press ▲ or ▼ to select Fax Only,
    Fax/Tel, External TAD or
    Manual.
    Press Menu/Set.
    4 Press Stop/Exit.
    Setting the Ring Delay
    The Ring Delay sets the number of times the MFC rings before it
    answers in Fax Only or Fax/Tel mode. If you have extension
    phones on the same line as the MFC or subscribe to the telephone
    company’s Distinctive Ring service, keep the Ring Delay setting of 4.
    (See Operation from extension telephones on page A-7 and Easy
    Receive
    on page 4-4.)
    1 If it is not illuminated in green, press (Fax).
    2 Press Menu/Set, 2, 1, 1.
    3 Press ▲ or ▼ to select how many
    times the line rings before the MFC
    answers (00, 01, 02, 03 or 04).
    Press Menu/Set.
    (If you select 00, the line won’t ring at all.)
    4 Press Stop/Exit.
    Initial Setup
    1.Receive Mode
    Current Receive Mode
    Fax : Fax Only
    F/T : Fax/Tel
    TAD : External TAD
    Mnl : Manual
    Setup Receive
    1.Ring Delay
    Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
    Time
    This should take care of it for you.
    NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
    1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
    2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
    3. Press the [Start / Enter] button.
    4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
      NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
    5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
    6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
    7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
    Dec 13, 2007 | Office Equipment & Supplies
    Sharp UX-B750 Inkjet Fax Logo
    279 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
