Question about Canon SPEEDLITE 580EX TTL Flash
Coroded bateries were left in my speedlight, now it will flash but not in sinc with shutter
    Scholar:
  • 97 Answers
You will have to disassemble the unit to see if acid leaked in the circuits and damaged them if so you can either replace the parts by shopping at radio shack and replacing all the damaged components or you will have to replace the entire unit if you don't feel comfortable trying to repair the unit some parts might have the numbers eroded off from the acid or a damaged circuit board and the unit will be difficult to repair and further total replacement would be warranted you can find them on ebay.com here is the search settings hope this helps.
http://photography.shop.ebay.com/Flashes-/64353/i.html?_nkw=SPEEDLITE+580EX+TTL+Flash&_catref=1&_dmpt=Digital_Camera_Flashes&_fln=1&_trksid=p3286.c0.m282
Posted on Aug 30, 2010
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Delay between presssing down shutter and flash going off
Check the flash mode. If Red-eye reduction is turned on, there'll be a delay while the red-eye lamp lights.
Dec 24, 2009 | Nikon Speedlight SB-800 TTL Flash
SB flash does not synk with d90
Are you waiting for the flash to be ready before you fire the first photo?
What shutter speed are you using? Are you trying to sync at too high a shutter speed?
Jul 05, 2009 | Nikon Speedlight SB-600 TTL Flash
Shows STBY
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
May 29, 2009 | Nikon Speedlight SB-800 TTL Flash
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Shooting with External Flash
Without more information, it sounds like the flash may be set to a manual mode. Try setting the flash to an auto mode. The display should indicate something to the effect of "E-TTL" or maybe just "TTL". The reason your images are blurry, would be due to a slow shutter speed being used on the camera. If your flash is not set to trigger automatically, then the camera will use the slowest shutter speed to acheive the proper exposure of the image. My assumption would be that if you were to take two images back-to-back with the speedlight set to your current setting, one with the speedlight the other with the pop-up flash, the latter would not be blurry. Hope this helps.
Dec 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Speedlight 600
What symptoms? If you are getting over exposed pictures and you're shooting in daylight, it may be because of the sync speed limitation means your camera can't use a fast enough shutter speed to get a correct ambient exposure. This is only likely in A mode, though.
If this is the problem, and you're using A mode, turn down the ISO to 100, and close down the aperture until the "Hi" warning goes away.
Nov 18, 2006 | Nikon Speedlight SB-600 TTL Flash
Cannot connect Speedlight to SK-6 Power Bracket
A change was made in the flash power connector on later Nikon Speedlights and the Power Bracket Model SK-6. It is impossible to connect a flash with the older (square) connector to a newer SK-6 or vice versa. The flash on the left has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
A change was made in the flash power connector on later Nikon Speedlights and the Power Bracket Model SK-6. It is impossible to connect a flash with the older (square) connector to a newer SK-6 or vice versa. The flash on the left (above) has the older square-style connector, while the one on the right has the newer connector. Both the Speedlight and the SK-6 must have the same style connector. Please contact Nikon Service about having the units modified for compatibility.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Canon SPEEDLITE 580EX TTL Flash Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
