Question about Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
I bought a c-map max for my navman 5500 tracker but it wont recoginse the card. I then put it in mynavman 6500 trackfish, and it worked.... any help?
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
What memory card does the 5505 take
CLICK HERE for all the info.
CLICK HERE for the Manual.
Your specific question's answer is on page 7 of the manual:
C-MAP™ chart cards have chart details required for navigating in a particular region. When a chart card is plugged in, the extra details automatically appear on the TRACKER chart display.
The TRACKER can use NT, NT+ and NT-MAX cards.
C-MAP™ user cards are used to store navigation data. Each user card expands the TRACKER memory and allows the data to be transferred to another TRACKER easily (see section 14).
Note: The older 5 volt user cards are not supported.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Navman TRACKER 5505 GPS Receiver
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
No gps fix NavMan trackfish 6500
my navman trackfish 6600 gps is aquireing and will not give a gps fix ,I have also had the screen ghosting when I enlarge the area with no detail, the unit is 4 years old .
May 09, 2009 | Navman Trackfish 6600 GPS Receiver
Navman f20 need to install USA map
Unfortunately, the maps for this device are not free. If he didn't send you the USA map you will probably have to buy it on SD card from their website. Sorry I couldn't be more help.
Jan 29, 2009 | Navman F20 GPS Receiver
I need a manual for Navman trackfish 6600
I need a manual for a Navman Trackfish 6600. Can i download it or where can i purchase it from?-
Dec 30, 2008 | Northstar Explorer 660...
Navman tracker 5600
I have bought a boat with a Navman Tracker 5600 and I want to buy a C-Map card for it for my region, I have been told I need "the old black type" but no one can tell me what the card or type of card is called. I also need to find out where I can purchase onr from. Thanks to anyone that can help in anticipation, regards Trev T
Jan 22, 2008 | Navman Tracker 5600 GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
1,264 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
