Question about Exercise & Fitness
I have aI have a sportcraft treadmill that stops working after 7
I have a sportcraft tx200 treadmill that stops working after 7 seconds
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 07, 2016 | Sportcraft Exercise & Fitness
Tx200 sportcraft treadmill
Grainger usually has the best products at a reasonable price
Item # 44N745
Silicone Aerosol, Container Type Aerosol can, Size 11 oz., Temp. Range -40 Degrees F to 500 Degrees FVOC Content 55 Percent, Specific Gravity 0.72O-rings
Oct 15, 2013 | Sport & Outdoor - Others
see the video attached and proceed according. God bless you
Jun 13, 2013 | Exercise & Fitness
My TX4.9 treadmill stops after 7 minutes.
overheating treadmill belt motor stops due to worn motor armature brushes
Feb 18, 2013 | Sportcraft Exercise & Fitness
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
I have a sportcraft treadmill tx335 it shows error 7 why and how do i fix it
Error code seven is due to the console getting locked. I called Sportcraft and they said to do this: Unplug the treadmill for five min and then re-plug the treadmill. Now push the ON/OFF switch to ON and insert the safety key. Now press the MODE and STOP button simultaneously. Without releasing the buttons take out the safety key and insert it again. Now you should hear a beep and the display will come on. Release MODE & STOP and now press the Speed increment (+) button
Oct 31, 2010 | Health & Beauty
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
I have a sportcraft tx 2.5 treadmill thats needs it stops on 7 sec evertime i moved and lost the manual to it what should i do
Can you give more details? are you saying it stops 7 seconds after you step on it, (every time)?
If so, have you had the treadmill a while? this is an indicator of a worn belt. the belt is not sliding like it should, and drawing too much current. your control board will 'clip' the current off after a pre-set time, to avoid burning up components.
other things it could be:
1. your belt is too tight. did you tighten it lately? When did your treadmill start doing this?
2. The motor is going bad, and drawing too much current.
3. motor control board is bad.
look at your motor's current rating: measure the current draw when you get on it. if the current draw is ~ 80% of the rated current of the motor, and your belt is good,..and not too tight, it could be the motor.
if the treadmill is stopping while only drawing 4 or 5 amps, I would lean towards the control board is bad.
cheapest way to get started troubleshooting. Ensure the belt is not too tight, (adjust to only about 3 inches slack, when you pull up on it). next. buy some belt lubricant and lube it up.
If this doesn't fix your problem, keep looking for other fixya help. someone with SportCraft TX 2.5 specific experience. Sorry, I only have generic help here.
good luck.
Jan 25, 2010 | Exercise & Fitness
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
942 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
