Question about Acard Technology ARS-2033S DVD-R Burner
Acard duplicator error it says ' copier f/w fail please update fw
2 Suggested Answers
SOURCE: Copier F/W Fail Please Update FW
see disply F/W fail update firmwar
Posted on Aug 16, 2009
Problem with duplicator controller Acard 2037P.After the first or second sucefully duplicating/burning of all seven CD DVD,the controler stop to "listen the orders".when i push the any button of...
Could be either. Perhaps the unit is overheating. Try aiming a fan at the ventilation holes and see if that makes a difference. Another possibility is that there are some capacitors that are aging. It could also be software, so check the manufacturers site for firmware updates. The unit probably doesn't require drivers, so I don't think you'll find any. The other possibility is the software you use to author the disks.
May 27, 2014 | Acard Technology 15 CD DVD Duplicator...
Acard 2039A copy problem
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and writing or just take a specific brand of DVDs or CDs and then It fails over time, it's normal failure behaviour. Pls rate my solution if I helped.
Nov 19, 2013 | Acard Technology Acard ARS-2039A 1-to-9...
Acard duplicator comes up 'source drive not ready' it has been working fine untill now is it just a case of replace the disc drive or is it more serious?
Have you tried to upgrade firmware ?
If this is up to date and still causes function error try to Completely uninstall all software for it and reinstall....
May 15, 2012 | Acard ARS-2030PC 1-to-3 Target USB Card...
Acard duplicator - 'Source drive not ready'
When you push the button to open/close the drawer, does it work,
i.e., is there electrical power reaching the drive?
Did you put a disk into the "source" drive?
Is the same disk recognized when you put that disk into any other computer?
If so, then the "source" drive is damaged, and needs to be repaired/replaced.
Jul 18, 2011 | Acard Technology 15 CD DVD Duplicator...
Firmware needs to be updated for a cd/dvd duplicator # 2039. where can i find a update
Hi spencer prin,
You can download the latest firmware here..http://www.acard.com/english/fc0101.jsp
Hope i solved your problem, if i did then please vote and rate me,
Regards,
Salman
Feb 13, 2011 | Acard Technology Acard ARS-2039A 1-to-9...
I am getting this error when trying to duplicate my advertisments discs "burner mixed or firmware version mixed" and it is even nt getting into advanced setup.. wht shud i do ?
If you can not go into " Advance setup" then you can't update your writer firmware through controller. The only thing you can do is connect you writer to a PC, update writer one by one and put all back to tower.
If all your writers are same brand ( NEC ) , but different model, this solution won't take care you problem. In this case, two way you can do:
1, Find out what the model that you have most and buy that one from any seller, remember " Update F/W to same version.
2. Get a ACARD controller, ACARD controller can mix brand, model and firmware in one system.
Dec 31, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
On boot the message "copier f/w fail please update fw" appears.
I have flashed just 1 DVD drive, years ago. It was easy when you knew the trick. The download site should have told you how. You must get the firmware to read and remember the update flash.
That said, I stopped flashing firmware long ago. If it ain't broke, don't fix it. I was given this info and I pass it on. Lots of folks update, upgrade and flash their way to real trouble.
Jul 03, 2009 | Acard Technology ARS-2033S DVD-R Burner
Acard Technology ARS-2033S DVD-R Burner Logo
260 people viewed this question
Top Acard Technology Computers & Internet Experts
Alun Cox
DROPNDEAL
DROPNDEAL
Robert Graf
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
