Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
What do wire colors mean for ao smith dl1056 blower motor
    President:
  • AO Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 31, 2010
  • Clarence Little Jan 20, 2015
    thank you, you were right on the money! I'm taking industrial maint. at c.o.s and I'm also a verry exp. welder. I'll be sure to check in here alot so I can return the favor! thanks again.
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
I have an A.O Smith SE2F01 115/220v Type C electric motor, it has 4 wires: White/Black/Blue/Red, I want to know which is which? And Does it need a capasitor?
Wiring diagram appears on side of unit.
With wire colors.
Capacitor: each electric motor has a run-winding and a start-winding with capacitor.
Both windings receive power.
The start-winding gets a surge of power from the capacitor > and this starts the motor.
The run-winding brings motor up to full speed.
Copy following link for motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 19, 2013 | AO Smith Pool & Spa
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
What are wire colors on A O Smith UST1102 ?
115v motors are wired with Black (hot) White (neutral) and Green (ground)
Rod
www.uspartscenter.com
Jan 21, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Oct 23, 2012 | Pool & Spa
Need som help with a wiring question on a CD#52 AO Smith 1/2 hp blower motor. the furnace runs wiring for a white, red and black not sure which wires go where.
Look at the schematic on the inside panel of the cover you removed. It should have the schematic with the wires and colors labeled as to what goes where. The wires are a common, run and start wire. They schematic should identify the wire by color and motor connection by number. You should be able to see the numbers on the motor by the connection. hope this helps.
Jan 29, 2011 | Heating & Cooling
AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Nov 25, 2009 | AO Smith Air Tools & Compressors
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
2,167 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
